where to run power wire for amp through firewall in XJ? - JeepForum.com
post #1 of 6 Old 08-15-2005, 06:46 PM Thread Starter
Magic2979
i need to know where the best place is to run my power wire for jy amp through my fire wall in my 2000 XJ. right now i have it running through my fender and then through the door. but that has screwed up my weather seal making my door leak and my jeep smell pretty
also pics of how you ran your wire would be a great help.. i plan on doing this on friday since i will have a section of my carpet up on my passenger side..
MY XJ Wheeling videos
2000 Cherokee//3" lift 34s
1988 Cherokee- street xj project
Magic2979 is offline
post #2 of 6 Old 08-15-2005, 07:36 PM
Slamm36
Slamm36's Avatar
look for a place were wires already pass through the fire wall u should be able to find a spot that u can put the power cord
-Wyatt
1996 Laredo 4x4 I6 177800 Miles - Slightly Modified
Optima RedTop | BFG T/A KO's 30x950 | 22" Cherry Bomb
KOR Crossmemeber | V8 UpCountry Springs | Dayton Timberline MT 31x1050
K&N Drop-In | Homemade QD's | KOR Radiator Support
Slamm36 is offline
post #3 of 6 Old 08-15-2005, 08:49 PM
oct7brian
oct7brian's Avatar
Why not find a safe place to drill a hole and put the wire through it. I did that in my Grand Cherokee and got a rubber grommet from Autozone to protect the cable from the sharp metal. You could even go the route of sealing it in the hole with Black RTV if you wish. Just my .02
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #4 of 6 Old 08-15-2005, 09:29 PM
Thayer
Is your amp on the passenger side or driver side?
1997 Cherokee Sport NAXJA #1255
RK 4.5" LA Kit
Thayer is offline
post #5 of 6 Old 08-15-2005, 10:31 PM
fortcollinsram
fortcollinsram's Avatar
On my 1996, I drilled a hole in the firewall directly to the outside of the heater/AC box. it was a pain in the *** to drill the hole for a 1ga. wire but it worked out. Best part is it puts the wire in a straight line to the battery...
The phrase "Go for it, man" is usually followed by carnage and a trail full of broken parts
-1996 XJ, 4.0L, AW4, np242, D30/Chrysler 8.25"
-1989 XJ, 4.0L, AX-15, np231, D30/D35
-1987 K5 Blazer, EFI 468ci BBC, sm465, np205, Dana 60/14 bolt, rear discs, DEEEEEETROITS front and rear, hydro assist, cross-over steering. It's loud, locked and loaded
fortcollinsram is offline
post #6 of 6 Old 08-16-2005, 05:22 AM Thread Starter
Magic2979
my amp is on the passenger side
Help passing power lead through ZJ firewall DanZ Audio, CB & Ham Radios, GPS, & Electrical 7 09-29-2009 06:32 AM
Getting power through WJ firewall GrandPrix104 Audio, CB & Ham Radios, GPS, & Electrical 1 05-02-2008 11:17 PM
Quick ??? Running Sub power through the firewall Knocky Audio, CB & Ham Radios, GPS, & Electrical 4 04-27-2008 09:54 AM
JK firewall wire pass thru enigma5300 Audio, CB & Ham Radios, GPS, & Electrical 2 09-05-2007 07:24 PM
Power wire through wrangler firewall. gsxr150 Audio, CB & Ham Radios, GPS, & Electrical 6 07-19-2007 10:28 PM
