Where to mount CB in YJ with A/C? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Where to mount CB in YJ with A/C?
TJ Dana 60 - BOLT IN REARSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEBds fox ipf 2.0 racing series shocks now available at rock
Unread 10-29-2001, 01:42 PM   #1
OhYeah
I have a 91 YJ with A/C and I am wondering where i should mount my CB. I do not really want an over the head mount. If I had a Tuffy console, could I mount it where the stereo goes?
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline   Reply With Quote
Unread 10-29-2001, 03:46 PM   #2
evilpsych
yeah you could if your cb is DIN size or smaller in dimensions..
Awwwwwwwwwwww... So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline   Reply With Quote
Unread 10-30-2001, 08:58 AM   #3
Willis91YJ
Chris,
You could reverse the mounts and put the unit on the floor in front of your shiftr and the handset mounted somewhere else. Just don't wrap the cord around your neck!
Willis
Black 91' YJ with fresh 4.0, Sitting on 31x11.5 Mickey Baja MTX's on 15x10 AR767, Borla Stainless cat-back, free flow cat, it seems like I keep breaking necessary parts just about the time I get enough money together for the fun stuff!!!
Willis91YJ is offline   Reply With Quote
Unread 10-30-2001, 11:28 AM   #4
evilpsych
it'd be kinda hard to read it that way.. it'd be tilting away from you..
Unread 11-13-2001, 05:35 PM   #5
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I just finished mounting my CB in my Jeep .. I destroyed my cigarette ashtray (don't smoke, don't need it) and fit a Realistic CB into the space created .. check my home page for more information (under the modifications section).
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
  • From street to trail, '88 YJ on 38" tires does it all well
  • Silver 2006 TJ Unlimited, zombie ready as the daily-driver
  • a Kawasaki KLR650 DualSport bike
NaeKid is offline   Reply With Quote
