Where to mount cb radio - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Where to mount cb radio
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 08-02-2007, 02:13 AM   #1
Diz
Does anyone have a cool mounting spot for their CB? I don't know where to put it with the stick in the middle, and passenger side glove compartment is just too far. It just doesn't seem like it can go anywhere except the underside of the roof. Pics would be nice.
Diz is offline   Reply With Quote
Unread 08-02-2007, 02:25 AM   #2
jeepgeek2k
I was thinking about this the other day.. One location on mine was between the seats facing up, or zip tied to the roll bar between the seats for weekend trips. Wires might get in the way though..
I'd also like to hear about some good spots too..
I wave.. do you??
No Jeep No Trail!!
There's just something about a Jeep that puts a smile on my face, and my passengers!!
jeepgeek2k is offline   Reply With Quote
Unread 08-02-2007, 06:11 AM   #3
TJ_Jackson
This is how I have mine setup
2004 Jeep TJ Sport - Dual tops | 5spd | 30" BFG A/T's | Cobra CB | PA Horn | 4' Wilson Antenna | Panasonic 7113-U Head Unit | Infinity Kappa's 4x6"/ 5 1/4" | 10" Bass Bazooka | Ipod direct | XM Direct | GPS | K&N FIPK Gen II | Reese Class III Hitch| Rancho Steering Stabilizer
TJ_Jackson is offline   Reply With Quote
Unread 08-02-2007, 06:17 AM   #4
frankiefire702
Here's where I mounted mine in my old rig.
06 tj locked on 36's.
frankiefire702 is offline   Reply With Quote
Unread 08-02-2007, 06:21 AM   #5
rjt36
2009 JK Wrangler
I've got mine mounted in the same spot, just rotated 90 degrees. The only thing I don't like about it being there is that the passenger seat hit it when I tilt/slide it forward. Other than that, it's a prefectly good spot.
I used to have it on the driver's side, which I liked a little better, but it has since been displaced by the OX shifter.
EDIT: By the way, that was me on 17S the other day.
rjt36 is offline   Reply With Quote
Unread 08-02-2007, 06:25 AM   #6
frankiefire702
Ahh nice rig!
Unread 08-02-2007, 01:58 PM   #7
tomgpdx
I bought some 1" aluminum angle material from the local hardware store and attached my CB to the plastic molding, just above the inside rear view mirror. Routed all the wiring under the plastic trim on the windshield. Out of the way, easy to reach and you can hear the stock speaker when you're going down the highway.
Tom
Fresno, CA
tomgpdx is offline   Reply With Quote
Unread 08-02-2007, 02:07 PM   #8
Crashnburn80
A common spot is next to the Tcase shifter on the side as far forward as possible.
If you haven't bought a CB yet, I'd recomend getting the Cobra75wx so you don't need to worry about the space for a mounting location. Thats what I have and will be installing this weekend.
http://www.cobra.com/index.php?page=...duct_id=5&id=1
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Unread 08-02-2007, 04:51 PM   #9
MY3UKAHT
UkieJeeper
MY3UKAHT's Avatar
Have mine set up like TOMGPDX; I know it's difficult to see, but it's right above rear view mirror. It's a small RadioShack CB, similar to the Uniden 510, so it's nice and compact.
MY3UKAHT is offline   Reply With Quote
Unread 08-02-2007, 06:06 PM   #10
KevinKrupp
1994 XJ Cherokee
keep the pics coming. i just bought my cobra CB this week and im waiting for my jeep to get back from the shop to mount it. i was thinking of doing it under the glove box right above the passangers left knee. would this work, i dont have any jeep to look at at the moment for ideas.
[B]-'94 Xj Country
6.5" Rough Country lift with bushwacker fender flares, 35" Maxxis Bighorn Tires, 15" Extreme black steel rims, Rancho steering stabilizer, 40 series Flowmaster Muffler, Custom 1/4" steel Front and rear bumpers with stinger on the front, 4 6.5ton D-Rings, 5' whip on the rear bumper, and a Warn 8,000lb winch on the front bumper, side rock sliders[/B]
KevinKrupp is offline   Reply With Quote
Unread 08-02-2007, 07:04 PM   #11
J.Bob
CB under a shelf in the back
I took out the back seat and put in a wide shelf the full width of the back of my 05. I put gear on top of the shelf and a cooler and more gear under it. I mounted my CB under that shelf between the seats. It's a bit of a pain to fine tune because it's behind me but it's out of the way and once it's set up, it's easy to use.
J.Bob is offline   Reply With Quote
Unread 08-02-2007, 07:10 PM   #12
Chris @ GATR
Here is my setup.
Got ignorance? Please see below.
[QUOTE=kd4yor;4763909]Chris, I just think your having buyers remorse for all the work in your 8.8 for no added gain (over the Dana 35).[/QUOTE]
Chris @ GATR is offline   Reply With Quote
Unread 08-02-2007, 08:00 PM   #13
#686 Sahara
Heres mine http://i166.photobucket.com/albums/u...a/DSC_0107.jpg http://i166.photobucket.com/albums/u...a/DSC_0109.jpg
#686 Sahara is offline   Reply With Quote
Unread 08-02-2007, 08:58 PM   #14
Scottsdale Jack
I put my CB on the back side of the console. No muss, no fuss. Ran the wires between the passenger seat and the console up to the aux plug for power. Mounted the magnetic antenna on the LF fender, with the lead coming back under the hood and down the firewall under the driver floorboard and then up through a rubber drain plug, under the driver seat back to the CB unit itself. Very sanitary install and works good. Not real fond of the magnetic antenna on the LF fender, but getting used to it. Did the same thing on my old YJ and it worked for 10 years. Problem with mounting the antenna anywhere else if it is close to the Jeep body (as on the rear bumper or whatever) then the body absorbs all the transmitting energy and only vehicles behind you can hear you. Up on the LF fender it seems to work ok.
Scottsdale Jack is offline   Reply With Quote
Unread 08-04-2007, 10:35 PM   #15
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
winch controller plug and cb where the radio used to be...
in my yj...
radio shack external speaker mounted where the parking brake pedal used to be.
you can hear it from 100+ feet away with the volume up... and you can easily hear it as the boggers humm @ 60mph on the hwy with no doors or top.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS!
Big-n-Broke-YJ is offline   Reply With Quote
