where do you mount your TJ's cb radio - Page 4 - JeepForum.com
post #46 of 141 Old 11-24-2008, 09:03 AM
clmsnfan123
where in SC are you?
clmsnfan123 is offline
post #47 of 141 Old 11-24-2008, 09:43 AM
TJwrangler4.0
do the cb's that are mounted to the side of the console on the drivers side ever get in the way of your right leg? or if it's mounted on the passenger side under the dash, will the seat still tumble forward? sorry for all the questions lol
TJwrangler4.0 is offline
post #48 of 141 Old 11-24-2008, 10:07 AM
deltabravo
On the Rockhard cage:
deltabravo is offline
post #49 of 141 Old 11-24-2008, 10:39 AM
silvergoat
My jeep may be gone but im still here.
There's the right wheelbase for every obstacle and the right obstacle for every wheelbase.
silvergoat is offline
post #50 of 141 Old 11-24-2008, 11:10 AM
Rowingfish87
http://www.jeepforum.com/forum/f20/cb-options-my-tj-624096/
^ Post #6 is my set up ^
and here is another link to a cb thread
http://www.jeepforum.com/forum/f9/where-did-you-put-your-cb-624626/
2002 Sahara 4.0L/NV3550/NP231/D30/D44
35x12.50x15 MTRs
RC 2.5" Lift & 1"BL
1998 Dodge Ram 2500 4x4 CTD
Rowingfish87 is offline
post #51 of 141 Old 11-24-2008, 12:35 PM
Okiiashi
Okiiashi's Avatar
Well I got a Lil Uniden and used the mounting kit from Jeep Outfitter
|¯¯l,[___],
l---L--OlllllllO¬
()_) ()_)---)_)RED JEEP #446
“Even if you’re on the right track, you’ll get run over if you just sit there” - Will Rogers
Okiiashi is offline
post #52 of 141 Old 11-24-2008, 11:39 PM
Yellow TJ
I use a cobra 75 WX ST Compact/Remote Mount CB Radio with SoundTracker® and NOAA Weather. I mounted the "unit" in the glove box and put the mic on the center consol by the 4wd shifter...I dont seem to kick it and most people ask when they get in where it is. I can still fit some manuals in the the glove box but it does take up a good chunk of the space there.
http://cobra.com/index.cfm?fuseactio...category_ID=30
Yellow TJ is offline
post #53 of 141 Old 11-25-2008, 08:15 AM
easytim
1974 CJ5
I have the Uniden pro 538W - it measures 6 1/4 X 8 1/4 do you think I can make the mounting kit work with this size?
What if the hokey pokey really is what its all about
easytim is offline
post #54 of 141 Old 11-25-2008, 09:19 AM
JasonJW
Anyone use that Jeep Outfitter bracket with any of the cages that mount to the dash bolts in that same area? Is there enough room to clamp it in there between the two? I was thinking of picking one up to mount an Icom 2100H in that spot but figure there isn't much point if I end up having to fab something anyway when I put a cage in.
02 TJ Sahara, 2.25"BB + 1.25" BL, 32" Maxxis Bighorns
JasonJW is offline
post #55 of 141 Old 11-25-2008, 09:25 AM
MudDuck99
2014 JK Wrangler
I Am Wiring Up My Cb In The Morning...we're Taking Out The Glove And Cutting A Slot In The Back Of It So My Cb Will Fit.
MudDuck99 is offline
post #56 of 141 Old 11-27-2008, 06:15 PM
timc
Not at all, can't even lean my right leg all the way over and touch the radio.
timc is offline
post #57 of 141 Old 11-27-2008, 06:24 PM
easytim
1974 CJ5
WILL A LITTLE BIGGER RADIO FIT the mounting bracket from Jeep Outfitter?
The radio I would like to use measures 6 1/4 x 8 1/4 can I make a bracket to get this to fit?
The radio they put on it is 5 x 7 in
easytim is offline
post #58 of 141 Old 11-27-2008, 06:28 PM
bandit455
that was the first thing i thought when i saw this, I would like to run an or fab sport cage as well. another thing is does it obstruct road view.
bandit455 is offline
post #59 of 141 Old 11-27-2008, 06:29 PM
bandit455
any pics of your rig?
post #60 of 141 Old 11-27-2008, 07:12 PM
easytim
1974 CJ5
I'm 6'5" and I sit up high in the seat, I don't think blocking road view will be an issue for me.
http://webpages.charter.net/easytims/jeep.htm#CB
easytim is offline
volume and radio controls on tj's steering wheel! jeep2008 TJ Wrangler Technical Forum 17 09-09-2008 05:55 AM
where to mount a Cb radio? Kevinstravels Wrangler General Discussion 18 08-21-2008 07:38 PM
CB Radio Mount omnicitadel JK Wrangler Technical Forum 4 05-01-2008 11:22 PM
Is the Transmission mount on the TJ's 00-04 NV3500 centered between the frame rails? JeepRocks86 TJ Wrangler Technical Forum 4 04-15-2007 09:28 PM
cb radio mount panhd TJ Wrangler Technical Forum 6 03-15-2002 04:19 PM
