where do you mount your TJ's cb radio - Page 10 - JeepForum.com
post #136 of 141 Old 01-05-2012, 11:13 AM
Squint77
Squint77's Avatar
We have two wranglers so here are the set ups:
In the TJ, we just glued it to the dash:
In the LJ, I cut out some of the center console and originally glued it, but everytime I go infor wiring or HVAC issues, it is a pain to reglue so I finally just wedged it in there by making a bracket that screws into the side of the CB. The cool thing is that it does not move at all and I did not have to drill into my dash. The bracket just pushes against the bottom of the dash and when I want to remove the dash, it is easy reinstall the CB with the side screws:
Pic of the bracket:
Speaker:
Antenna:
It works extremely well
Squint77 is offline
post #137 of 141 Old 07-11-2012, 05:21 PM
1997tjwrangler
Originally Posted by sportcoupe View Post
I put both my radio and CB in-dash.
I really want to do this, but the CB I want is larger than yours. Did you have to cut into the plastic bracket above the air control box? It looks like I would have to cut a lot of plastic out of the cover and the brackets. Do you have any pics of the setup behind the black cover?
1997tjwrangler is offline
post #138 of 141 Old 07-19-2012, 11:25 PM
BechBarg
I have mine mounted in the tuffy overhead security console. My cobra 29 fits great and I can lock it. My Uniden bear cat fits, but I can't lock it because the knobs stick out to far. My antenna brackets were made by Arizonarockyroad.com they make tons of different mounting solutions for antennas and radios. Gotta say I love the brackets I bought and they helped give my rig it's unique look. I will post pics of the mounted radio as soon as I take pictures of it. \m/
BechBarg is offline
post #139 of 141 Old 07-21-2012, 10:51 PM
kb2seo
Have you considered the transmission Console? As long as the ground return in on something in the tub, like a screw from the seat, or is wired to the battery direct, it will do fine, Keep the wires as short as practical. I mounted my Icom 2100 H like that- it does not bother the passenger at all, I was able to tuck everything neatly under the console . Can send photo if you wish.
kb2seo is offline
post #140 of 141 Old 11-21-2012, 09:18 PM
TXRanger
What are you guys using to mount it to the side of the console? Surely everyone's not spending $25 for this...
http://www.quadratec.com/products/96080_200.htm
Also, you guys mounting under the glove box, what are you using?
'04 LJ - 3" RCD SL w/Bilsteins - Metacloak front fenders - D30/D44 w/4.88s
315 Cooper AT3s on stock Moabs w/1.25" Spidertrax spacers
TXRanger is offline
post #141 of 141 Old 11-21-2012, 09:47 PM
Coyote56
I bought the Smittybilt GEAR overhead console. Put all of my storage pockets to the rear and drilled in a place for my CB mount in the overhead.
I am using a Uniden Bearcat 880.. great CB has weather alerts... etc. A lot better than those 30 dollar wal-mart radios. I would recommend it if you use CBs alot.
Coyote56 is offline
volume and radio controls on tj's steering wheel! jeep2008 TJ Wrangler Technical Forum 17 09-09-2008 05:55 AM
where to mount a Cb radio? Kevinstravels Wrangler General Discussion 18 08-21-2008 07:38 PM
CB Radio Mount omnicitadel JK Wrangler Technical Forum 4 05-01-2008 11:22 PM
Is the Transmission mount on the TJ's 00-04 NV3500 centered between the frame rails? JeepRocks86 TJ Wrangler Technical Forum 4 04-15-2007 09:28 PM
cb radio mount panhd TJ Wrangler Technical Forum 6 03-15-2002 04:19 PM
