Where is the 50 amp fuse for the windows in a 95 Grand Cherokee? - JeepForum.com
post #1 of 4 Old 07-24-2011, 10:30 AM Thread Starter
Patrice
I can't find the 50 amp fuse in my 95 Jeep Grand Cherokee LTD
Patrice is offline
post #2 of 4 Old 07-25-2011, 05:04 PM
mylt1
mylt1's Avatar
never heard of a 50a fuse for windows. thats a high rating for just window motors. should be in the fuse box but i doubt it will be 50a.
mylt1 is offline
post #3 of 4 Old 07-25-2011, 05:08 PM
wsar10
2003 WJ
If your window motors draw 50a....I would say there is quite an issue.
There are additional relays inside the glove box on 93-95's
QUOTE=billzcat1;wsar10 is right on point on this oil thread - as usual. Anyone reading this would be well-served taking his advice.
-03 WJ laredo 4.0 120k a few minor mods
-93 XJ 5spd, 3" zone lift
wsar10 is offline
post #4 of 4 Old 07-25-2011, 07:38 PM Thread Starter
Patrice
Thanks for answering. You are both right. I got that from another post for the same issue but they were not right. There is a 30 amp relay on the inside fuse panel that controls the windows. But my issue was the black wire in the boot in the drivers door. I did not find it at first because the broken wire was way up in the boot and it broke off right where it goes into the door. I can see the end of the wire coming out of the door and barely grab it with a pliers but I cannot pull it out enough to get a good end to solder. I even took the door panel off to try to push from the inside while pulling from the outside but no luck. I could put attach a wire to the end that goes into the body, open the door and touch it to the end sticking out of the door to raise and lower the windows. That works but is not very practical. Not sure if I should try to solder such a short end right into the plastic.
Patrice is offline
Windows won't go down in '95 Grand Cherokee LTD Patrice Audio, CB & Ham Radios, GPS, & Electrical 1 07-25-2011 07:44 PM
Help please! 2000 Cherokee windows won't close... carylouwho Audio, CB & Ham Radios, GPS, & Electrical 2 07-11-2011 09:52 AM
1998 grand cherokee ltd doors and windows locking & unlocking madmonk9 Audio, CB & Ham Radios, GPS, & Electrical 1 04-18-2010 06:21 PM
88 cherokee fuse keeps blowing jeepscout Audio, CB & Ham Radios, GPS, & Electrical 5 11-20-2008 05:34 PM
Can a 2002 Grand Cherokee Radio fit a 1996 Grand Cherokee limited? banzayworld Audio, CB & Ham Radios, GPS, & Electrical 4 10-20-2002 10:25 PM
