Whats the difference between these types of AGM batteries? - JeepForum.com
post #1 of 4 Old 09-27-2013, 12:04 AM Thread Starter
Maverickxeo
Ultra flat plate agm or Spiral grid agm?
Is one better than the other?
The reason I ask is because Canadian Tire has the two types listed; and both are the same price for a Group 34; but the Spiral Grid AGM has poor(er) ratings over the Flat Plate AGM. Both are the same brand (Motomaster) but I dont know much about the type of batteries.
Maverickxeo is offline
post #2 of 4 Old 09-27-2013, 04:48 AM
Holder350
1995 XJ Cherokee
Flat plate agm has more area to use.
Look at a spiral cell battery, lots of empty space around the cells.
I would go with the flat plate if its no higher.
Sent from my phone where correct grammar is difficult.
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
post #3 of 4 Old 09-27-2013, 08:37 AM
biffgnar
biffgnar's Avatar
What Holder350 said. If you search there are actually graphic represenations showing how more efficient use of space. I think Jerry B posts it in battery threads occassionaly.
biffgnar is online now
post #4 of 4 Old 09-27-2013, 04:52 PM
Gearhead31
Ditto. I have an altima yellowtop(should have gone bluetop, but what can I do now). If i had done more research into the different types of AGMs, I'd have looked towards flat plate. They seem to have a little better storage capacity, and slightly better lifespan under typical use for their size/weight. Other than that, there really isn't too much difference AFAIK.
Most people I know recommend altima bluetops as a minimum, especially if winches and such are used but the flat plates typically go for more cost than the benefits warrant, here.
Gearhead31 is offline
