Waterproof Stereo (head unit) - JeepForum.com
post #1 of 18 Old 12-02-2013, 02:05 AM Thread Starter
Tjaxon07
My TJ usually spends the summer topless. I'm looking for a head unit that'll withstand the elements. I know "check marine stereos" but I have an most are only water proof to an extent. I'm also looking for speakers for the soundbar.
Any advice would be awesome . I'm aware this topic has been brought up before, but from mobile search, it was done in 08. I'm sure there's some cool new toys out.
Thanks
Aaron
Tjaxon07 is offline
post #2 of 18 Old 12-03-2013, 05:52 AM
hewesyourdaddy
2011 JK Wrangler
Check out Fusion marine head units. I think the larger units are similar in dimension to DIN sized auto units. Probably won't need an amp either if you are just running stock speaker set up.
hewesyourdaddy is offline
post #3 of 18 Old 12-03-2013, 06:00 AM Thread Starter
Tjaxon07
I'll check that out today. I had already installed Rockford T1 6.5 in the soundbar. No amp though. Only thing amped is my P3 sub. But I'm thinking of things to do to hide it too
Tjaxon07 is offline
post #4 of 18 Old 12-14-2013, 03:27 AM Thread Starter
Tjaxon07
Is there any other advice? I saw these and 400 is steep to pay when I live in the ghetto. Haha. My luck it'll get stolen.
Tjaxon07 is offline
post #5 of 18 Old 12-14-2013, 05:13 PM
freeskier93
I've never had an issue with plain old head units. Marine is a waste of money IMO. Marine just means corrosion resistant and a true water-proof head unit is going to cost way more than it's worth. And for speakers, any speaker that doesn't have a paper cone can be considered "water-proof".
freeskier93 is offline
post #6 of 18 Old 12-14-2013, 05:39 PM
chriskeenan
use one of those flip covers from marine units.
Like this
also there isn't much that will get you "water proof", water resistant and splash resistant should be fine for rain showers. any high pressure water or submersion and you'll be screwed, so don't take your topless jeep through the car wash and don't use it as a submarine and you'll be ok.
chriskeenan is offline
post #7 of 18 Old 12-14-2013, 06:13 PM Thread Starter
Tjaxon07
No submarine use?!? Nooooo!!!!!
That was what I was going to do. Actually I was hoping to install a boat motor on it like in UK Top gear..
Will that cover work for any single din unit
Tjaxon07 is offline
post #8 of 18 Old 12-15-2013, 01:07 AM
chriskeenan
They're made for single din units
post #9 of 18 Old 12-15-2013, 04:50 PM Thread Starter
Tjaxon07
I'll see if I can find one. I need it
Tjaxon07 is offline
post #10 of 18 Old 12-15-2013, 05:58 PM
rubibluejay
This was posted by a JeepForum member a while back; not sure if he still posts here, but he did make this video.
Not sure I would do such a test...
Jay
rubibluejay is offline
post #11 of 18 Old 12-15-2013, 06:01 PM
jay-h
An alternate approach would be a Tuffy box with radio compartment. Water, theft resistant, and you can use any radio you like.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #12 of 18 Old 12-15-2013, 06:09 PM
jeepwrangler97
Those cover things aren't a bad I idea. I'd thought about one at one point.
Imo, if you're want to keep the radio dry in case you get caught topless in the rain, get a windjammer...most of the rain getting up front when you're topless in the rain (& moving) is from the back of the jeep.
I actually did a 3hr drive topless with a windjammer, from one coast of FL to the other & it was raining the whole time. Some of the rain on the trip got pretty heavy, but with the windjammer on, I/the radio/the windshield stayed dry.
...well I got wet in traffic & on some on/off ramps...but hardly wet
Obviously, in FL there's lots of rain & as much as I try to avoid it, I've driven topless in rain multiple times.
My alpine headunit has gotten wet multiple times & works perfectly. I try not to let water get "in" it though.
Sent by a messenger bird
jeepwrangler97 is offline
post #13 of 18 Old 12-15-2013, 07:23 PM
gily25
There's not really so way to make the head unit waterproof. You can try using no head unit and an amp instead, stash the amp in the center console. The best head unit option is splash resistant which is all most marine units are, and corrosion resistant boards. If a unit gets wet, don't power it up and it should be fine when it dries.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #14 of 18 Old 12-15-2013, 08:18 PM Thread Starter
Tjaxon07
Thanks for the input! I'm going to look at all the suggestions. I'll keep in touch when I replace it.
Tjaxon07 is offline
post #15 of 18 Old 12-17-2013, 09:13 PM
chriskeenan
Also if you don't mind voiding warranties you can add a "conformal coating" over the PCB of automotive stereos. It comes in a spray can, you apply it like spray paint, and check it with a UV light. Most if not all marine units have this done already.
