Voltage gauge drops to zero intermittently - JeepForum.com
post #1 of 4 Old 07-31-2008, 01:06 PM Thread Starter
BlackBellamy
BlackBellamy's Avatar
I have recently started having this intermittent problem. I'll be tooling along, everything great, and I notice my 'check guages' comes on because the charging system voltage gauge shows zero.
I shut off the Jeep and turn it on again and one of two things happens:
1) The voltage gauge shows a good charging system voltage. No more problems (at least for a while), I'm good to go.
or
2) The voltage gauge will show a low charging system voltage - somewhere around 12-13 volts. The gauge will then fall to zero after a minute or two, especially if I accellerate past 40 mph. If I repeat the turn off/turn on process eventually it 'fixes' itself.
This started happening to me about two months ago, once here and once there, then it didn't happen for weeks, and now I've had this problem like three days in a row.
I've checked all the connections at the battery and the generator, and everything is nice and tight. The generator belt is good too.
I'm not too electrically inclined. Is there something I should check specifically? I have a multimeter so if anyone has a suggestion on what I should check and where I would appreciate it.
The top and doors on this vehicle are designed only for protection against the elements. Do not rely on the top and doors to contain occupants within the vehicle or to protect against injury during an accident. Wear seatbelts at all times.
BlackBellamy is offline
post #2 of 4 Old 07-31-2008, 02:10 PM
mylt1
mylt1's Avatar
check the connection to the gauges themselves. could be loose there.
mylt1 is offline
post #3 of 4 Old 08-01-2008, 11:01 AM Thread Starter
BlackBellamy
yeah will do - a mechanic friend yesterday told me it sounds like the gauge so if it's not a loose connection i'll see if another gauge (i got a spare, not oem but it will do) exhibits the same problem
post #4 of 4 Old 08-17-2008, 08:15 AM Thread Starter
BlackBellamy
Nope, it was the alternator. Buck-twenty five out of pocket and replaced the alternator yesterday after it died and stayed dead.
What happened was I went wheeling in the mud and didn't clean out the alternator sufficiently. It would work ok, except when under heavy load/rpms/hot it would start to crap out a little, giving 12-13v instead of 14+. Eventually it would crap out totally - except when I shut of the engine and started again it would go back to work and behave normally because it would cool off a bit.
After I took off the old one I gave it a couple of whacks with a hammer and this big cloud of dust came out
258 looses oil pres and knocks....intermittently IdahoJeeper Engines & Drivetrain 0 12-05-2009 10:28 PM
Headlights work intermittently salami Audio, CB & Ham Radios, GPS, & Electrical 4 11-12-2009 10:07 AM
Battery gauge drops out while driving Dh7 Audio, CB & Ham Radios, GPS, & Electrical 1 09-02-2009 11:00 AM
4.0 intermittently burning oil Dannn Engines & Drivetrain 4 08-17-2009 07:30 AM
YJ voltage gauge, battery drain littlejohn Audio, CB & Ham Radios, GPS, & Electrical 1 09-20-2004 07:51 AM
