Volt meter = 12 volts for a minute then ~9.5 - JeepForum.com
post #1 of 2 Old 10-09-2015, 07:50 PM Thread Starter
thelazerviking
EDIT: SOLVED! I TAPPED THE BACK OF THE ALTERNATOR WITH A HEAVY PIPE. SEEMS LIKE THE BRUSHES GET STUCK/ WORN OUT.
2001 XJ
The nut fell off my battery strap, it shook around and the caps came off, voltage dropped to 9..."check gauges" light comes on
Got a new battery and terminals, same problem.
I turn it off, start it up, 12 V, run it for 30-60 seconds and then the voltage drops down to ~9,9.5. This is consistent, every time for 2 days now.
Anyone seen this?
I'd rather change an alternator than PCM. Doubt it's a loose wire. I'll check the alternator tomorrow.
thelazerviking is offline
post #2 of 2 Old 10-22-2015, 07:19 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Typically with later XJ and the TJ, if the voltage meter reads around 9 volts there is an alternator issue, usually sticky/worn brushes. If the voltage gauge reads 19 volts, there is a connectivity issue, and you need to look at the wiring and and wire connections to the battery and alternator. This is assuming your battery has tested good.
CJ7-Tim is offline
