Uniden Pro 510 CB Radio Any Good?
#16 | |
I've been running the Uniden Pro 538XLW (weather band) for 10 years now and I've found that the transmitter seems more powerful than the 510, that we ran in our buses, although it does have a larger footprint
#17 |
Do it right or not at all
![]() Join Date: Jan 2003
The Pro538 and Pro510 both have the identical 4 watt output which is the maximum legal output.
And Rallykid, to have a CB "peaked and tuned" means, for those who don't know this, that it is being modified to produce more power than the legal 4 watt output. We don't allow the recommendation of illegal things like that here in JF so I edited that out of your post.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#18 |
I'm happy with what I ordered regardless.
I'm also excited about seting it up next week when it arrives. I'll need to run my hard top more now, don't want anybody stealing the only thing worth stealing on my rig! Any mount idead for the actual CB? I'm not sure what I'm doing about that yet.
/l , [____], l---L--[]lllllll[]-_ ()_) ()_)==@=)_) |
#19 |
#20 |
Wow that explains everything!
Thanks!
#21 |
Got my eye on you.....
The CB does come with a bracket. Hangs very nicely from the YJ lower dash support.
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#22 | |
I have had radios from the factory that were putting out 2.4-3.4 watts which were less than the 4 watt legal maximum. After changing the mic to replace the cheap mic that came with the 510 and having it peaked it was reading exactly 4 watts which is the legal limit. I am not condoning breaking the law, I am saying make sure you actually get what you are paying for so you can use it to it's maximum efficiency. That is one of the reasons to change the mic as it cannot handle audio over about 2.5 watts. You don't need a huge (and illegal) 500 watt amp but the difference between the 2 watts that you may be getting out stock and the 4 watts that you should be getting (and will after having everything calibrated) can make a huge difference when the terrain is not flat. |
#23 | |
Having said that, I would rather have a radio with exceptional modulation that is slightly down on power than a radio that has the proper output power and poor modulation. Neither is worth a **** without a good antenna and proper installation. A cheap radio with a great antenna with outperform a poor antenna with the best radio. |
#24 | |
The level of modulation that assures full RF power output has to more to do with the modulator (audio amplifier) circuitry than the microphone. Most microphones are capable of providing 100% modulation when the transmitter's modulator is up to snuff. And you might be able to fool some of the people some of the time with your claim that "peaking and tuning" is only to get it up to the maximum legal 4 watt transmitter output but you're not going to fool me or many others who know what that term really means. Plus peaking and tuning does not affect the modulator which is not much more than an audio amplifier circuit. And as said above, an amp'd microphone usually creates more problems than it is worth... overmodulation, hollow-sounding audio, unnatural voice, and just generally a crappy sounding signal. I've been using standard microphones since the early sixties, including what came on my Uniden CB, Kenwood TS-850 HF transceiver, Icom ICV8000 2m rig, as well as all the military (ground-ground, air-ground, ground-air) HF, VHF, and UHF rigs I used to handle and they all worked just fine with their non super-duper microphones. ![]()
#25 |
I guess I should have been more clear with that explanation. No, the mic has nothing to do with the power output, it is a modulation issue as was mentioned. Also I was not referring to a power mic but a standard mic that comes with most full size cbs. The one I am using is from a pc76xl. At 4 watts the small mic that comes with the unit will not modulate properly but the larger mic works fine.I was told by several cb shops that if you tune this unit to make the full 4 watts that it should then the standard mic will have modulation problems. I agree that overmodulation is a problem but it is also an issue when it goes the other way. I will see if I can come up with the test results from where mine was tested when it was peaked with the standard and the upgraded mic. I don't have access to them right now as I am posting this from my blackberry.
#26 | |
There's a guy (actually more of a nut) who runs a CB store called The Mud Shack in San Diego who has variously told me he has a PhD in electrical engineering (which is a lot of bull) as well as stuff that would make any second-year EE student (my background is EE) cringe. I just laugh, shake my head, and walk out after making my purchase of some doo-dad he happened to have in stock. The bottom line is that very few CB shop people know as much about CBs as they want you to think they do. They're usually nothing more than a hobbiest/CB-nut who is maybe one or two steps ahead on CB than the average person is and that's about it. When you get into anything advanced, they're normally lost... though they can often bluff you pretty good. ![]()
#27 |
Jerry,
I guess people take their radios to the CB shop because most competent techs won't work on a $40 radio. People ask me daily to look at their radios. My standard answer, "It will be less expensive to replace the unit." GlennA |
#28 | |
The reason I went with the 510 to begin with is it would fit in the Honda Prelude I was driving at the time. |
#29 | |
#30 |
Glenn, the only thing a 520 adds over a 510 is the RF Gain control (not a needed control for a trail-use CB) and a PA (public address) function. Other than that, they are identical in performance, size, and how they operate. What do you mean by "set and forget"? I've been using CBs since the sixties and I'm not familiar with what you're decribing there.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
