uConnect for 2012 Compass Latitude - JeepForum.com
post #1 of 2 Old 09-14-2014, 04:29 PM Thread Starter
jdrobis7
2012 MK Compass
Does anyone know if the 2012 Jeep Compass Latitude should have uConnect available? I have searched elsewhere, and can't find a real definite answer.
I would like to know if it should be there before I go inquire about installation.
Thanks for your help.
jdrobis7 is offline
post #2 of 2 Old 02-13-2016, 06:48 PM
ahogston
2014 MK Patriot
I have a 2014 Patriot, pretty much the same thing, and am looking to add UConnect to my vehicle as well. From what I've found so far, as long as your radio has the buttons on the radio, it is possible to add UConnect. If yours is like mine, when you press the phone button, it says UConnect not found. Theres a separate UConnect module that you need installed, as well as a harness connecting it the back of the radio, a microphone, and an optional iPod connection as well. I'm still searching, but these kits run for close to $300 from Mopar. In addition, the module, once installed, needs to be flash-programmed at a dealership. From what I've read, its important to make sure the dealership has done this programming before. I've read on this forum of some dealerships not being as experienced, and I assume ended up wasting money on them.
Good luck, and hope this helps.
ahogston is offline
2012 , availability , bluetooth , compass , uconnect
