two stage plan - JeepForum.com
post #1 of 3 Old 10-18-2002, 05:39 PM Thread Starter
Tyler Dirden
two stage plan
I was going to get something really, really cheap to satisfy my cb needs. I have since decided to buy a good antennea first (which is pretty cheap, anyway).
For my impending trip, I have borrowed a decent hand-held, and I'd like to pick up an antennea this weekend. Then in a week or two (after I know what I need/want in a cb radio) I'll pick up a cb unit.
Thing is, I don't know what to look for. I've heard of Firestick, is this a good way to go? Which one should I get?
HELP!
td
\oo/_ _\oo/
2003 Rubicon
'El Negro'
Tyler Dirden is offline
post #2 of 3 Old 10-18-2002, 09:54 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
I've never been a big fan of fiberglass antenna's. You can break them to easily in the cold weather and the range you get out of them doesn't seem to as good as a whip style like a Wilson or K-40 type. As far as CB's go, it depends on how much you want to spend and what it will be used for. For under $100 you could go with a Uniden 510 not a bad little radio, but lacks the features of higher priced ones. I personally would go with a Cobra 29 it has nitewatch faceplate, mic gain, SWR meter, and certain models have a weather channel. If price doesn't matter get a Connex or Galaxy. www.pinklightning.com Try this site for some info.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 3 Old 10-19-2002, 07:11 PM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Cool
krazykracker is right about inexpensive radios y Uniden, they are usually good enough.
Antennas, I like Wilson, I will be mounting a Trucker 5000 on the rear tire holder with an extended lower mast about 18"s. The extended mast will get the coil even or above the top where I like it. The top mast is a very flexible whip about 36" long but a shorter whip is available but I think it has an added coil in it; too many coils to snap.
Good Luck, everyone has their favorite, look and listen to friend and see what they are running and if you like how their antenna performs then buy it, at least until you have tried a few and determined which one you really like.
Scrambler82
Do it right the first time !
Scrambler82 is offline
Stage 8 X-Lock TSEJEEPERS Engines & Drivetrain 0 09-05-2008 04:38 PM
JKS J-Spec stage 4? R1Blueboy Tires & Wheels 0 05-14-2008 09:11 PM
Pro Comp 4' Stage 2 for 2001 TJ chris.hill Tires & Wheels 2 12-04-2007 07:27 AM
RF stage 2 in tuffy console? Scott-o Audio, CB & Ham Radios, GPS, & Electrical 4 05-09-2007 04:47 PM
Jet Chip Stage II cyan1de Engines & Drivetrain 4 07-31-2002 08:02 PM
