Two cobra CB radios - JeepForum.com
post #1 of 18 Old 01-31-2012, 08:02 AM Thread Starter
WoodiE55
Two cobra CB radios
Looking at buying either the Cobra 18 WX or the Cobra 29 LX.
I listen to sirius radio nearly 100% of the time while on the road so getting local weather isn't something I get while on the road so having a CB with weather channels is a nice bonus.
Which of these would you recommend?
04 Grand Cherokee Special Edition, 4.7 V8, QTII
WoodiE55 is offline
post #2 of 18 Old 01-31-2012, 10:09 PM
chris142
The29 has a noise blanker.
"Switchable Noise Blanker: For increased noise reduction." The 18 does not so you will hear every electrical noise within 50 ft w/o it.
I'd go with the 29 over the 18
chris142 is offline
post #3 of 18 Old 02-01-2012, 10:37 PM
SnowdogMarc
I've got the 29 in my rig as well. No problems with it at all.
My 2m rig gets more use both on and off the trail though.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #4 of 18 Old 02-02-2012, 11:43 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
I used to be a Cobra fan but not in many years... I just don't believe their quality is even close to what it used to be. If I needed another CB, I'd stick with either a Uniden like their Pro-510XL or Pro-520XL, or one of the Midlands that is similar. Uniden has an outstanding reputation among Jeepers and I've had zero problems with either of the two Uniden Pro-520XLs I've owned. I would still be running my original 16 year old Uniden Pro-520X if it and the Jeep it was mounted in hadn't been stolen last year.
Getting
Jerry Bransford is online now
post #5 of 18 Old 02-03-2012, 03:05 PM
JeepJeep31
I have been running an old Cobra 20 Plus. It started acting weird begging of this past spring. I spent about $130 getting it looked at. I think the receiver has went in it. I have power but get no RX or TX intermittantly. I am not sure though as I know very little about CBs. I hope I am not just throwing money at my set up again that is not the problem.
This week I looked at several Cobra and Uniden radios and I just order two days ago the Uniden 520XL. The radio cost me $46 shipped from overstock. It had every option I needed and some things my old Cobra did not. I will let you know what I think about the radio soon.
-- Oren --
I wave!!!
JeepJeep31 is offline
post #6 of 18 Old 02-03-2012, 03:25 PM
Ross
I have been running a Uniden PC68XL close to 8-10 years give or take. I have had no problems with it. Before I had that I had a couple cheap Maxxons but they didn't last very long.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is online now
post #7 of 18 Old 02-04-2012, 12:52 AM
SnowdogMarc
CB's are pretty much disposable. For what it costs to replace even the higher end models it's really not cost effective to bring them to a shop to repair them. 2 hrs labor and you can buy a high end unit new.
l_______
/l ,[_____],
l---L -[]lllllll[]-
post #8 of 18 Old 02-04-2012, 05:58 PM
JeepJeep31
Yea I wish I would have known that or got that advice last winter.
I ended up buying a new coax...not the problem, a new mount...not the problem, a new mic...not the problem but worked for a while. I even had the power boosted to 7 watts cause I wasn't getting even close to a mile.
The all of a sudden no signal. Power to the radio but no Tx or Rx no matter what channel or squelch level. The radio was in cb and not pa mode. It would work and then not on and off intermittently and not patter to why or when it wouldn't work.
I sure hope the radio was the problem. I use mine daily and from my readings most radios get 4 miles, one per watt, not under one.
-- Oren --
I wave!!!
post #9 of 18 Old 02-12-2012, 04:39 PM
JeepJeep31
To the original poster.
I received my uniden 520 xl pro. It is a sweet radio. I am still dialing it in and learning the radio but it is night and day from my old radio.
-- Oren --
I wave!!!
post #10 of 18 Old 02-12-2012, 04:42 PM
JeepJeep31
My old radio, with the same set up to power and antenna, would have static on power up to where sequelch had to be at least quarter turn to science. This radio has squelch set to off an no noise...even with rf gain turned up.
Perhaps my old radio was just that bad.
-- Oren --
I wave!!!
post #11 of 18 Old 02-13-2012, 09:43 PM
mitchrb1
To OP. I have a Uniden Pro 510XL in the Jeep because of all the good reviews I read from other Jeepers. One of the things that is great is the size. It's hard to find space in a Jeep sometimes. I used the Quadratec mount that goes on the side of the console. It's a pretty basic unit, manual tuning etc, but it really works well. No issues with this unit. Since my Truck is my DD, I don't miss the Weather band all that much.
I also have the Cobra 18 WXSTII in my Truck. I Like it for the weather band and the front speaker and the fact that it will monitor 2 channels at the same time. Little fancier scan and DX settings etc. I have had an issue with the MIC sticking on this one a few times. I have to speak then push the MIC button again or it sticks and I miss responses. It only does it when I first start using it. I am used to it now, but I am looking at getting another MIC for this one. I got it free so I can't complain.
Both units have good receive and send reception. Get an SWR meter so you can setup the Antenna properly and you shouldn't have any issues.
mitchrb1 is offline
post #12 of 18 Old 02-13-2012, 09:55 PM
Xjliker
My 2 cents worth here. LOL if your going to get a replacement mic get the astatic 636, the proven standard the truckers have used for years, it's a great upgrade from a stock mic , you can find for about $20 online.
Best wishes
XJ liker
Xjliker is offline
post #13 of 18 Old 02-14-2012, 11:00 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Been using Uniden for years CBs, Scanners and now even Wireless hse Phones, good product.
Cobra was once good, even the best in the hay day of CBs but they used Uniden main PCBs to run the radio.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #14 of 18 Old 02-16-2012, 02:40 PM
mitchrb1
Best wishes
XJ liker
Thanks, my Astatic 636l will be here tomorrow. Got for 20$ off of Amazon.com
mitchrb1 is offline
post #15 of 18 Old 02-16-2012, 09:35 PM
chris142
Thats a good mic but.......It's a noise cancelling mic. This means that it has what looks like a sponge in it to cancel out back ground noise.
Using it on a stock radio may or may not work well. Your audio may be very low with this mic, people may have trouble hearing you unless you talk loudly into it.
I common fix is to turn up the modulation inside the radio to make up for the low modulation.
Or it may be fine.
chris142 is offline
cobra , radio
Cobra CB radios joc1212 Audio, CB & Ham Radios, GPS, & Electrical 10 10-18-2011 07:54 PM
Handheld Cobra CB Radios? AnyGood? yzblue125 Audio, CB & Ham Radios, GPS, & Electrical 1 05-17-2009 03:47 PM
CB Radios fogertyb Audio, CB & Ham Radios, GPS, & Electrical 3 05-28-2008 07:27 PM
Difference between Cobra 19 Ultra III and Cobra 19 DXIV? Matt Graham Audio, CB & Ham Radios, GPS, & Electrical 4 04-12-2008 01:46 PM
Cobra all-in-one any good? I need help ! I don't know anything about CB radios! Polaris Junkie Audio, CB & Ham Radios, GPS, & Electrical 5 09-06-2006 07:50 PM
