Tweeter Question - JeepForum.com
post #1 of 9 Old 04-11-2007, 11:54 AM Thread Starter
chapladley
Tweeter Question
I am the owner of a 2000 jeep grand cherokee limited and am having a problem with the tweeters in the dash.
I have the inifinity gold system and when I turn the volume up, to even a moderate level, I hear a annoying rattle/hum coming from the tweeters. Consequently, I have been only using the back two speakers by switching the control knob on the factory head unit.
I find this very obnoxious and would like to find a cheap/easy way to fix it. Is it possible to just cut the wires running to the tweeters, or will that mess up my whole stereo?
I am not very knowledgeable about audio stuff at all so I was hoping to get some input from other owners. Thanks in advance for your help.
chapladley is offline
post #2 of 9 Old 04-11-2007, 06:15 PM
C2U5H
C2U5H's Avatar
you can cut the tweeter wires with no ill effects concerning the working ability of the system... but you will have no highs up front.
you could, however, replace the tweeter easily with a pair from crutchfield (they have cheap ones that'll work just fine for the factory stereo).
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #3 of 9 Old 04-11-2007, 06:26 PM
Prot
Prot's Avatar
2014 JK Wrangler
According to Crutchfield:
No direct factory replacements available. Your factory tweeter does not match any aftermarket size exactly. Call us for details about available space in your factory locations for custom mounting.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #4 of 9 Old 04-11-2007, 06:31 PM
DefStatic
True, there are no direct fit from Crutchfield. I believe the indash ones are some weird 3". But that doesn't mean you can just use some 1" tweeters with a mounting bracket of sorts in the same location without any major modifications.
DefStatic is offline
post #5 of 9 Old 04-11-2007, 07:21 PM Thread Starter
chapladley
Cool. Thanks for the help.
post #6 of 9 Old 04-11-2007, 08:07 PM
Prot
Prot's Avatar
2014 JK Wrangler
I would consider a surface mount with a swivel, mounted on the dash.
Prot is offline
post #7 of 9 Old 04-11-2007, 09:51 PM
Blake
Redefining body roll
Blake's Avatar
Just an FYI, the x-over points on those factory tweeters are pretty low, the get near full-range sound from the amp.
1991 Lexus LS400
Daily Beater
2006 Ford F250 Larait
6.0 Powerstroke | 4x4 | Crew Cab
Blake is offline
post #8 of 9 Old 08-18-2007, 08:09 PM
JeepMan7070
Found a pair
I found a pair of OEMS at a website called www.jeeptweeter.com . They were something like 90 bucks for the pair..... worked for me...
JM
JeepMan7070 is offline
post #9 of 9 Old 08-19-2007, 01:29 AM
CMARJEEP
CMARJEEP's Avatar
i bought a pair of tweeters from bestbuy because i had the same problem. youll have to fab up some of your own mounting brackets in most cases but thats easy. just pop up the cover over the tweeters (the whole thin cover that runs under the whole windshieild). cut the clips off the factory system, splice the wire and hook them up. the aftermarket offers much better highs than stock anyways. good luck.
CMARJEEP is offline
TJ Tweeter Brackets? gov-t_mule Audio, CB & Ham Radios, GPS, & Electrical 27 09-27-2013 12:19 PM
TJ tweeter locations? Pics? rubibluejay Audio, CB & Ham Radios, GPS, & Electrical 4 08-14-2008 09:44 AM
Tweeter Location??? jirvin8 Street Jeep Forum 8 01-21-2008 11:38 AM
Hmm .. Where to put the tweeter? UltimatE Street Jeep Forum 10 04-28-2007 07:44 PM
Need some help! This tweeter is driving me nuts! CRCoatings Audio, CB & Ham Radios, GPS, & Electrical 3 11-06-2004 03:47 PM
