Turn signal wiring? - JeepForum.com
post #1 of 7 Old 06-15-2017, 11:45 AM Thread Starter
19Cherokee96
Turn signal wiring?
The turn signals went out in my 96 cherokee, Every other light works. Brakes, Hazards, headlights (high & Low beam), running lights etc... i have changed the flasher relay, checked fuses, and changed the multi-function switch (turn signal assembly on column) and still nothing, not a sound or glimmer of light from the turn signals.. Any thoughts or suggestions will be greatly appreciated!! its a wiring nightmare under my dash from previous owner, will try to post pictures of what im working with...
19Cherokee96 is offline
post #2 of 7 Old 06-15-2017, 11:47 AM Thread Starter
19Cherokee96
Fuse panel and relay box.
post #3 of 7 Old 06-15-2017, 03:14 PM
cranbiz
I have seen worse wiring. Your fusebox, wiring wise, doesn't look bad. However, the mud and dirt indicates there may be corrosion in most of your connections and even behind the box. That needs to be addressed first.
06 KJ
12 JK,2.5" Teraflex lift,Bilstein 5100's,BFG KO2's P305/65R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 7 Old 06-15-2017, 03:31 PM Thread Starter
19Cherokee96
I just put that fuse panel in. It has good connections. The old panel had corrosion like you said.i had to replace it. The mud/water marks was slung on it by my boots... From what ive been told my jeep should have 2 flasher relays. 1 on top of the panel and 1 on bottom. Mine has none. Just a EP27 relay on the box hanging down that clicks with the hazards
post #5 of 7 Old 06-15-2017, 03:47 PM Thread Starter
19Cherokee96
Would the headlight switch have anything to do with the signals?
post #6 of 7 Old 06-16-2017, 09:05 AM Thread Starter
19Cherokee96
Im totally stumped here... Could anyone tell me how to maybe re-wire the turn signal wires to a new relay? or which wires on the turn signal switch itself are for the turn signals? or a basic description on how to rewire the turn signals? Any help or input would be greatly appreciated
post #7 of 7 Old 06-19-2017, 04:56 PM
cranbiz
You are going to have to find a FSM or post up in the Cherokee forum.
I don't know anything about the specifics of the Cherokee but could try to help if you have the wiring diagram out of the Service Manual.
06 KJ
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
