Tuffy Center Console - JeepForum.com
post #1 of 8 Old 08-30-2011, 07:48 PM Thread Starter
kash34
So my second aftermarket deck was just pried out of my dash the other night. This time they took a 9 and box combo from the back as well. Looking into buying a Tuffy Center Console with the compartment for mounting a deck.
Was hoping that someone can clear up for me whether or not the retractable lid for the separate compartment actually locks?
All the reviews say that the main compartment is 2.5x bigger and locks, but doesn't specify if you just flip open the other side and yank out the deck.
Also, if you have this installed, what do you do with the gaping hole in your dash? Any other advice/tips would also be appreciated.
*2006 Automatic LJ
kash34 is offline
post #2 of 8 Old 08-31-2011, 02:02 PM
BearinNM
Kash,
Not sure which Tuffy you are looking at but my unit, from 20 so years ago has the main compartment and up front one for the headunit. On mine there is a seperate lid for the front, which swings to the front of the entire console. When it is closed, its lip fall under the main lid, and is also locked down tight. I cannot imagine that this would have changed, otherwise it would not be advertised as security for a stereo.
Not sure on the gaping holes on an LJ, but in my YJ it was a great place to mount a power inverter. I run a lesser wattage one there that was not expensive at all so if it is stolen no big. I keep my big one stashed under the hood. Could also be a good spot for just a tray to catch possibles, perhaps for the cell phone, lots of possible uses. Heck you could even create a flat "cover" and use it for aux. switches for other gear.
Craig
BearinNM is offline
post #3 of 8 Old 09-01-2011, 11:04 PM
jclauson
i vote aux switches!
1990 YJ w/ lots of home made sh*t
check it out
http://www.jeepforum.com/forum/f22/hysterias-90-yj-build-1190617/
jclauson is offline
post #4 of 8 Old 09-02-2011, 11:36 AM
tuffy2
Vendor
*2006 Automatic LJ
The stereo lid will actually lock under the main, larger lid, so they're both secured with one lock. This way, you can have the main lid closed while you're driving (to use the armrest) and have the stereo lid open so you can access your tunes.
Tuffy makes a couple different products to address the radio dash hole - a tray that fits in the space for a bit more storage, or a blank-out plate that can be used for switches, etc...check out our dealers for a good deal!
http://www.tuffyproducts.com/p-196-1...tout-tray.aspx
http://www.tuffyproducts.com/p-197-1...out-cover.aspx
tuffy2 is offline
post #5 of 8 Old 09-02-2011, 01:09 PM Thread Starter
kash34
Thanks!
kash34 is offline
post #6 of 8 Old 09-04-2011, 11:06 AM Thread Starter
kash34
If you get just the rear console, is there a way to modify it so that your deck can be hooked up inside the main storage?
kash34 is offline
post #7 of 8 Old 09-05-2011, 12:14 AM
bdheaton
Junior Member
*2006 Automatic LJ
You can close it off with a plate and mount some switches. If you don't feel like cutting the plate, Quadratec has a block-off plate with backing frame.
bdheaton is offline
post #8 of 8 Old 09-06-2011, 09:10 AM
tuffy2
Vendor
You probably could - it just wouldn't be as clean an install as if you used a stereo console. Attach it to the inside wall of the console and put a surround around it and you'll still have a good amount of space for storage, I think.
tuffy2 is offline
advice , console , deck , stolen , tuffy products
How do I wire a stereo in a Tuffy Center console? lilirish10245 Audio, CB & Ham Radios, GPS, & Electrical 5 01-13-2010 08:05 PM
Tuffy center console Buford Audio, CB & Ham Radios, GPS, & Electrical 2 05-29-2009 05:04 PM
Tuffy Center Console w/speaker?? bronze493 Audio, CB & Ham Radios, GPS, & Electrical 2 12-04-2006 11:30 AM
CD/MP3 in Tuffy center console wyldejackyl Audio, CB & Ham Radios, GPS, & Electrical 3 03-31-2004 12:09 PM
do it yourself tuffy center top console drunksmurf Audio, CB & Ham Radios, GPS, & Electrical 6 12-04-2003 05:03 AM
