Trouble Code Reading Without Scantool - JeepForum.com
post #1 of 5 Old 11-23-2004, 12:31 AM Thread Starter
MechMan422
Junior Member
MechMan422's Avatar
1991 XJ Cherokee
I wanted if anyone knew how to read a trouble code on my OBDII equipped 2000 jeep cherokee sport. I know on an OBDI system you could cycle the key on/off and the check engine light would flash the code, but is there something similar i can do to an OBDII system, like jumpering some connectors, or cycling the key on/off a certain number of times? i know you can use a scan tool to read the codes real easily but i want to know if there is any other way to view them?
Thanks in Advance!
"True success in life is enjoying all those little things that keep you from being a success"
MechMan422 is offline
post #2 of 5 Old 11-23-2004, 06:44 AM
C2U5H
C2U5H's Avatar
absolutely! it's actually pretty fun...
put key in ignition, push and hold the odometer/trip mileage button (the little black one that comes out of the gauge cluster). turn the key to the "ON" position (where all the electronics turn on) while still holding the odometer/trip mileage button..do not start the Jeep! just turn it to "ON," the release the button.
the gauges will start their "dance:" calibrating themsleves, and the digital odometer readout will countdown (or does it count up? )...AFTER it's done calibrating, the digital odo readout will display any error codes.
haven't had to check any error codes, but it's fun to watch
hope this helps
~J
oh BTW, this works on my '99 TJ Sport..pretty sure it's the same for a '00
2012 Crush JK Rubicon on 2.5" and 37s
- see sidebar
C2U5H is offline
post #3 of 5 Old 11-23-2004, 10:11 AM
BigWaylon
tubework is cool...
BigWaylon's Avatar
the key on-off-on-off-on method is not just for OBDI vehicles...I've had it work on some OBDII as well, just either of my TJs...
FYI...AutoZone reads/clears them for free...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #4 of 5 Old 11-23-2004, 07:33 PM
RWB214
RWB214's Avatar
There is no way to do it without a scan tool on any 98+ XJ. It is possible on TJ's but not Cherokees (I've tried every possible method on mine). Doing the above trick will test and calibrate all the guages but won't read out any codes.
Mabye if you swapped a TJ instrument cluster into an XJ... are they compatable?
RWB214 is offline
post #5 of 5 Old 02-12-2005, 09:28 PM Thread Starter
MechMan422
Junior Member
MechMan422's Avatar
1991 XJ Cherokee
yea they are compatable but that wouldnt affect the opperation of the gauges. youd have to swap the PCM's for that to work and i dont think you could do that sucessfully.
02 liberty trouble code ratsrides1 Engines & Drivetrain 1 12-11-2008 10:00 PM
SWR Reading watkins 92 yj Audio, CB & Ham Radios, GPS, & Electrical 2 09-14-2007 03:59 AM
OBD 2 Trouble Code? Tonymac Engines & Drivetrain 1 06-05-2007 05:31 PM
No SWR Reading NoUse328 Audio, CB & Ham Radios, GPS, & Electrical 11 10-15-2005 07:15 PM
actron scantool evilpsych Engines & Drivetrain 0 10-16-2001 11:49 AM
