Trailer Wiring Harness Questions - JeepForum.com
post #1 of 2 Old 03-12-2013, 01:27 PM Thread Starter
JeepNJenn
2015 WK
I installed the Rugged Ridge trailer wiring harness Sunday and realized that it was a pin harness and the trailer (M416) I am buying is a 7 pin set-up. I can't seem to locate which adapter I need to go from 7 on the trailer to 4 on the vehicle. I am sure they exist I am just not using the correct search terms. Would someone be kind enough to help me out? Much appreciate!
Edit:
I ordered the Reese Towpower 74607 7-Way to 4-Way Flat Blade Wiring Adapter and it appears to have female connectors on both ends of the adapter. I hope to find something I can either order from amazon Prime or pick up locally as I am picking up the trailer on Friday.
__________________________________________________ __________
2015 WK2 Overland ORA II
JeepNJenn is offline
post #2 of 2 Old 03-12-2013, 08:30 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
7-pin harnesses are for trailers with brakes and 4-pin harnesses are for trailers with only lights.
A 4 to 7 pin adapter will bring lighting to the trailer but no trailer brake functionality.
***Chris***
chris87xj is offline
trailer , wiring
