Towing Harness, bad ground? - JeepForum.com
post #1 of 3 Old 06-01-2009, 07:01 PM Thread Starter
funky_boss23
Tj Towing Harness, bad ground?
I attached my wiring harness to my tail lights and then to my trailer. During my light check, I noticed the brake lights on my trailer were more dim than usual. also, it seems my blinkers were reversed. Left on the steering column resulted in right on the trailer and vice versa. I thought I may have had the wiring harness reversed but that wasn't the case. Could there possibly be a bad ground somewhere in my tail lights on my 99 TJ? I have used the trailer with a different vehicle recently and did not experience any of the above mentioned. I have yet to try a different harness as well.
Any ideas as where to begin the search?
Thank you for your time and I appreciate the assistance.
JT
funky_boss23 is offline
post #2 of 3 Old 06-01-2009, 07:47 PM
spatulahunter
a bad ground could definitely cause dim lights but the reversed blinkers still doesnt make sense because they are different wires and there is no way a ground could flip them around. I would definitely try a different harness, it sounds like some of your pins may be out of order.
spatulahunter is offline
post #3 of 3 Old 06-05-2009, 05:37 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
sounds like either your tailight harness or your trailer is wired backwards. if the trailer works correctly on other vehicles, you need to flip the R/L wires on the tj to make it work with your trailer. R/L is a wiring issue, not ground issue. dim lights=poor ground, weak signal
make sure the ground wire on the tj side and the trailer side are good/clean/tight. also, make sure theres not alot of surface rust/grease on your trailer ball and cupler. the ground on the harness is usually in most cases is just a secondary and the trailer is actually primarily grounded through the ball to the vehicle. the white wire supplies a constant ground so that your lights dont flash when you hit a bump and the coupler rattles, or if your ball doesnt make good connection.
on a 4 way flat harness:
yellow-left side blinker/brake
green-right side blinker/brake
brown-running lights
white-ground
hope this helps. if you need more info just ask.
theGiantPanda is offline
Is this an OK ground? gmp211 Audio, CB & Ham Radios, GPS, & Electrical 4 06-28-2009 01:23 AM
towing wire harness 03Wrangler Audio, CB & Ham Radios, GPS, & Electrical 2 11-13-2007 11:25 AM
Bad Ground???? tobias94yj Audio, CB & Ham Radios, GPS, & Electrical 8 12-05-2006 08:46 AM
CB Ground? Armory Audio, CB & Ham Radios, GPS, & Electrical 1 06-19-2003 11:36 AM
