TJ Tweeter Brackets? - JeepForum.com
post #1 of 28 Old 09-21-2007, 11:18 AM Thread Starter
gov-t_mule
http://www.quadratec.com/products/14133_100.htm#
These brackets and tweeters are offered from quadratec. I only want the brackets to mount my own component tweeters on. Does anyone know of a source to get only the brackets or ones that will work?
Thanks in advance.
gov-t_mule is offline
post #2 of 28 Old 09-23-2007, 07:46 PM
SirGCal
SirGCal's Avatar
I wouldn't do it. Dash mounted tweeters are one of the worst spots in a TJ. I still don't understand why it's so popular and even more, why the new wranglers do it...
Anyhow, tweeters are far too directional and too sensitive to phase variation to be that close to the listener. You want them mounted as far away from your head, and as on-axis as you can get. Unfortunately in a TJ this doesn't work so well and you honestly get better sound from a good set of speakers in the dash or kick panel. The few times I have done component style tweeters, the most successful places I've found are just under the dash or in the kick panel.
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
post #3 of 28 Old 09-24-2007, 08:37 AM Thread Starter
gov-t_mule
Thanks for the headsup SirG! I've already got Polk db 525s, and they sound great. I was thinking about making the sound brighter, but this clearly isn't the route to take.
post #4 of 28 Old 09-24-2007, 08:42 AM
SirGCal
SirGCal's Avatar
There's a trick you can do to get more direct shot of highs out of the dash...
Take the grill off. Notice the grill slits are extremely thick and deep. This creates a channel the sound has to follow. If you grind down the back of the grill a little to change the channels to slits, it will let a lot more sound out (try listening without the grills on for an example. It won't be quite that strong modified since they will still block some.) Downside is if not careful, it can be an obvious change which might look a little odd. Also makes them slightly more vulnerable to a splash. I use a razor blade tool to clean them up after sanding or grinding. Don't go TOO far... Not all the way to the face.
It might get you the sound you're looking for, for free... Listen without your grills on to see if it's what you're looking for. If not, perhaps a brand of speaker change. Infinities are brighter than polks (which actually is why I don't like em, but if that's the sound you like, then you very well might. That's why speakers are so important for each person to choose themselves.)
SirGCal is offline
post #5 of 28 Old 02-02-2012, 09:52 PM
NalinMFG
Would you consider coming off of the lower door pins(angled up/in) as a good potential location?
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #6 of 28 Old 02-02-2012, 11:23 PM
SirGCal
SirGCal's Avatar
Not perfect, but much better then most. It can be done there very effectively if done well.
SirGCal is offline
post #7 of 28 Old 02-03-2012, 03:56 PM
gily25
That's about where the tj q pods have the tweeter.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #8 of 28 Old 02-16-2012, 01:59 PM
NalinMFG
Here is the solution I came up with for a few serious local guys looking for a more acoustically correct place to mount tweeters:
I do not have them in mass production, but if enough guys are interested I can run a batch. Hope that adds to your arsenal of options.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #9 of 28 Old 02-16-2012, 06:40 PM
gily25
Very cool...
gily25 is offline
post #10 of 28 Old 02-16-2012, 07:24 PM
SirGCal
SirGCal's Avatar
Originally Posted by gily25 View Post
Very cool...
Yes, and in a very good location too. Aimed right would work very nicely.
SirGCal is offline
post #11 of 28 Old 02-16-2012, 08:10 PM
NalinMFG
I'm 5'10" and this first set points almost directly at my face. I'd consider you the audio specialist of the forum...so you probably have more technical knowledge to offer, but from my experience this is the best way to do it (given that it's a Jeep!).
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #12 of 28 Old 02-16-2012, 11:15 PM
SirGCal
SirGCal's Avatar
The technical what & why has to do with the axis (where it is pointed) with distance differences between listening positions and each speaker. High frequencies are very susceptible to both effects where lower frequencies are a little more forgiving. But to keep it simple, that's why this position is a good choice.
SirGCal is offline
post #13 of 28 Old 02-16-2012, 11:21 PM
jharvey615
I would definitely be interested in a set of those brackets.
Don't out think your common sense!
jharvey615 is offline
post #14 of 28 Old 02-23-2012, 06:53 PM
NalinMFG
Thanks for the interest! I have a few sizes available right now, and should have a few more as I am able to test fit new brands. I'm planning on them going live this evening at http://www.nalinmfg.com/Tweeter-Mounts_p_22.html#
They fit CJ/YJ/TJ/JK's.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #15 of 28 Old 02-29-2012, 11:27 PM
Tr00b
Kick *** idea. Your website is bookmarked. Your 5" speaker adapters and the tweeter brackets will def be on my list... Perfect way to get a 5 1/4" component set crammed up front in a TJ... Too bad the sheetmetal on my door strap is bent to heck though
Tr00b is offline
TJ tweeter locations? Pics? rubibluejay Audio, CB & Ham Radios, GPS, & Electrical 4 08-14-2008 10:44 AM
Tweeter Location??? jirvin8 Street Jeep Forum 8 01-21-2008 12:38 PM
Tweeter Question chapladley Audio, CB & Ham Radios, GPS, & Electrical 8 08-19-2007 02:29 AM
Hmm .. Where to put the tweeter? UltimatE Street Jeep Forum 10 04-28-2007 08:44 PM
Need some help! This tweeter is driving me nuts! CRCoatings Audio, CB & Ham Radios, GPS, & Electrical 3 11-06-2004 04:47 PM
