TJ Speakers - JeepForum.com
post #1 of 8 Old 09-03-2012, 05:49 PM Thread Starter
Jeepster_4
TJ Speakers
My stock front speakers are shot and wont work, anyone know what size, what kind or any other specs i should get/know about before i buy?
Jeepster_4 is offline
post #2 of 8 Old 09-03-2012, 05:55 PM
thatguy69
I'm curious as well
98 TJ Sport 4.0 5 speed manual/4inch rough country long arm kit/35inch kevlar mtr tires with 17 inch moto metal skulls/
aussie lockers front and back/and a mean A$$ grind from 3rd to 4th!
thatguy69 is offline
post #3 of 8 Old 09-03-2012, 05:57 PM
MallCrawling
Stock are 4x6", but if you buy an adaptor you can fit 5.25" speakers in there, which sound much better
-Jimmy
MallCrawling is offline
post #4 of 8 Old 09-03-2012, 06:05 PM Thread Starter
Jeepster_4
what kind of adapter? im clueless.
post #5 of 8 Old 09-03-2012, 06:15 PM
esad_b
Here you go bud, complete tutorial and what adapters to get and how to install.
http://www.jeepforum.com/forum/f20/h...-pics-1244021/
esad_b is offline
post #6 of 8 Old 09-03-2012, 06:54 PM
krughzn
krughzn's Avatar
Nalin Mfg. They're a vendor on here. Quality stuff.
krughzn is offline
post #7 of 8 Old 09-03-2012, 07:00 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Aftermarket 4x6 speakers won't fit the non-standard 4x6 opening used in early TJs like the '97. The bolt pattern is different and there's a lot of cutting and drilling to make aftermarket 4x6 speakers fit and even then they won't fit properly. I know because I had a '97 and tried mounting aftermarket 4x6 replacments in it. Aftermarket 4x6 speakers do fit later model TJs, I'm not sure when Jeep standardized the front speaker opening.
You're much better off with installing the speaker adapter plate and running round 5.25" speakers instead which sound much better. Polk is one brand that will work well because it doesn't take a lot of power to sound good as many aftermarket speakers do.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #8 of 8 Old 09-04-2012, 01:32 PM
NalinMFG
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
help needed , jeep tj , radio , sound system , wrangler
I need new speakers WranglerRush YJ Wrangler Technical Forum 11 12-08-2008 08:44 AM
What Speakers to replace stock speakers with? MSG_TweetyBird Wrangler General Discussion 17 07-21-2008 01:16 PM
Marine Speakers vs Auto Speakers Sakis94Wrangler YJ Wrangler Technical Forum 14 06-11-2008 09:24 PM
speakers Alg3188 JK Wrangler Technical Forum 3 09-15-2007 10:48 AM
Where's the other 2 speakers ? jtstj TJ Wrangler Technical Forum 5 03-14-2006 05:26 PM
