TJ Sound System for $300 or Less - Page 2 - JeepForum.com
post #16 of 20 Old 06-11-2013, 07:07 PM
MyKeyB
This guy fits the budget and should work pretty good:
http://www.bestbuy.com/site/Clarion+...&skuId=8928257
Specs from Clarion:
http://www.clarion.com/us/en/product...559424485.html
As far as I know Clarion is still a pretty good company. It's not a large amp but it's not tiny so it may be a little harder to hide somewhere other than under the seat. Also at 95 watts x2 at two ohms it will not max out the speakers but that's plenty to make them loud. If your local Best Buy has the amp you should be able to hear it on the speakers, too.
Rust never sleeps...
MyKeyB is offline
post #17 of 20 Old 06-11-2013, 08:10 PM
gily25
You should be able to suspend most small amps under the steering column. Look or the threads in how to do the install. I forget the max amp footprint size. There are so many micro amps now...but on the $300 budget at bestbuy only it'll be tough to do better than the power pack.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #18 of 20 Old 06-12-2013, 01:33 PM
driggity
The Clarion XC1410 might be another choice for an amp. I think it is supposed to have a bit more power and is a bit cheaper at Best Buy than the Alpine Power Pack.
http://www.bestbuy.com/site/Clarion+...&skuId=8928178
driggity is offline
post #19 of 20 Old 06-15-2013, 10:03 PM
BuffaWrangler
Originally Posted by sammich View Post
This is the power pack amp I referenced...anyone have thoughts for this unit driving the Alpines or Polks I linked?
http://www.bestbuy.com/site/Alpine+-...&skuId=4769803
Just installed this in my YJ, powering some kicker 6x9's... love it. I have it stashed inside my Smittybuilt center console. Doesn't get hot. Just waiting until I Monstaline my tub before I wire up my Polk 4x6s to it. (need to move my head unit to the console too)
BuffaWrangler is offline
post #20 of 20 Old 06-16-2013, 06:40 PM
terpsmandan
2009 JK Wrangler
Height - 1-1/2"
Width - 2-5/8"
Depth - 1-1/2"
Weight - 3.3 pounds
Continuous Watts per Channel (4 Ohms) RMS - 45 x 4
Continuous Watts per Channel (2 Ohms) RMS - 45 x 4
Continuous Watts Bridged - 90
Peak Power Watts per Channel (4 Ohms) - 45 x 4
Peak Power Watts per Channel (2 Ohms) - 45 x 4
Max Power Watts per Channel (4 Ohms Bridged) - 90
Number of Channels - 4
1 Ohm Stable No
Amplifier Class and Type - Class D
Tri-Mode No
High-Pass Filter Yes
Low-Pass Filter No
Line-Level Input Yes
Speaker-Level Input Yes
Passthrough - No
Signal-to-Noise Ratio - 80dB
That is what I am running with my cde133. Can't say enough about it. Fits behind the climate control. Year and a half with no issues.
terpsmandan is offline
