TJ Sound System for $300 or Less - JeepForum.com
post #1 of 20 Old 06-05-2013, 06:04 PM Thread Starter
sammich
I've got a $300 gift card to burn at Best Buy. I want to add speakers and maybe an amp to my TJ without spending any $$$ out of pocket. Sound quality is still a factor.
I already have an old Pioneer DEH-6900UB in the deck, so that's covered. I'm not buying another head unit...this is just about speaker/amp setup I can get for $300 at Best Buy...they have to be in store or online. Not interested in a woofer.
Here are my deck's specs:
RMS Power Output - 22 watts
Peak Output - 50 watts
RMS Power Bandwidth - 50-15kHz
I've been looking at Alpine's SPS-510's for the front (requires a bracket?) and SPS-610's for the soundbar...so that at least gets me going. I haven't built a system in years and am pretty clueless on specs.
SPS-510: http://www.bestbuy.com/site/Alpine+-...specifications
SPS-610: http://www.bestbuy.com/site/Alpine+-...specifications
That speaker combo already puts me at $190.
So what do you guys think?
2004 Rubicon
sammich is offline
post #2 of 20 Old 06-05-2013, 08:57 PM
gily25
You'll need to get the dash bracket, check with nalinmfg.com he's a member here and has them on eBay too.
Alpine makes a good speaker, those would be a good choice but they run the Polk line buy one get one half off all the time.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #3 of 20 Old 06-05-2013, 09:04 PM Thread Starter
sammich
This Polk 6.5 speaker seems to be better spec'd than the SPS-610 Alpines...better RMS wattage, better freq response, and better sensitivity.
http://www.bestbuy.com/site/olspage....c=abcat0300000
Same with the 5.25" version...Polk vs. SPS-510 Alpine, the Polk appears to have better specs. I'm not a sound engineer, am I missing something here?
2004 Rubicon
sammich is offline
post #4 of 20 Old 06-05-2013, 09:06 PM
gily25
You should listen to the speakers everyone likes something different.
gily25 is offline
post #5 of 20 Old 06-05-2013, 10:14 PM
MyKeyB
Good advice but it will sound different in your vehicle. I have about $60.00 in my jeeps mids and highs right now. It sounds pretty good but my deck and amp has a ton of tuning options and I have a pretty good idea how to use them. I would guess your not an audiophile? I think you should be able to do allright at Best Buy on 3 bills. Make sure you go to your local store and check the dump table. Might be able pick up some nice returns for cheap. I picked up some garbage Rockfords components for cheap a few years ago from Best Buy. I replaced them with some cheap MTX 2 ways after the tweeters and crossovers went "splody" about a week after I bought them but hey... They where a great deal for some supposedly kick *** speakers.
Rust never sleeps...
MyKeyB is offline
post #6 of 20 Old 06-06-2013, 11:52 AM Thread Starter
sammich
It isn't that I'm not an audiophile, but I understand and accept the inherent limitations of the TJ for sonic quality, so I'll polish the turd to a certain point and call it good.
I really like what I'm seeing for those Polks. Any reason those 6.5" speakers wouldn't fit the soundbar? They're 2-5/16" deep.
http://www.bestbuy.com/site/Polk-Aud...=1218205765007
http://www.bestbuy.com/site/Polk-Aud...=1218207314797
Anyone have thoughts on an amp? I understand there's a small 4-channel power pack that can be mounted behind the stereo deck?
2004 Rubicon
sammich is offline
post #7 of 20 Old 06-06-2013, 01:42 PM
MLH34
my vote goes to the polkaudio also. I have the 6.5 inmy soundbar and like them. They are also marine certified so they function well in a trail jeep. If you look for deals they go on sale all thetime at best buy,a few weeks ago youcould get the 6.5 for 39.99 you can run 5.25 in the front without a plate by getting creative with mounting, many use 2 screws and zipties goodluck
MLH34 is offline
post #8 of 20 Old 06-06-2013, 01:59 PM Thread Starter
sammich
This is the power pack amp I referenced...anyone have thoughts for this unit driving the Alpines or Polks I linked?
http://www.bestbuy.com/site/Alpine+-...&skuId=4769803
Height - 1-1/2"
Width - 2-5/8"
Depth - 1-1/2"
Weight - 3.3 pounds
Continuous Watts per Channel (4 Ohms) RMS - 45 x 4
Continuous Watts per Channel (2 Ohms) RMS - 45 x 4
Continuous Watts Bridged - 90
Peak Power Watts per Channel (4 Ohms) - 45 x 4
Peak Power Watts per Channel (2 Ohms) - 45 x 4
Max Power Watts per Channel (4 Ohms Bridged) - 90
Number of Channels - 4
1 Ohm Stable No
Amplifier Class and Type - Class D
Tri-Mode No
High-Pass Filter Yes
Low-Pass Filter No
Line-Level Input Yes
Speaker-Level Input Yes
Passthrough - No
Signal-to-Noise Ratio - 80dB
2004 Rubicon
sammich is offline
post #9 of 20 Old 06-06-2013, 02:49 PM
gily25
Not to bash ya man but $60 isn't all that much for mids/highs, I thnk an xplod comp set cost more than that now. I'm running CDT comps backed by 100 atts rms on each side and that's just to get warmed up. For the average listener as the OP seems to be, a decent set of aftermarket speakers, backed by clean power and a reliable source signal is going to sound light years beyond the worn oem set-up. *2 cents*
The power pack is a great little amp, easy to stash in the dash. Some people have complained it doesn't seem to give rated power but all Alpine Amps are compliant (tested to do rated power). The PP will only give the polks you linked half power so you may want to go with the Alpines.
I would probably steer clear of the return table at bestbuy, most of it is returns from the install bay and some things can be seriously wrong with amps and speakers from there.
gily25 is offline
post #10 of 20 Old 06-06-2013, 07:37 PM
MyKeyB
Yeah. I didn't even think about it when I posted but I bought my rear fill speakers about 6 years ago on sale. My whole stereo other than my amp for the highs was less than $800.00 for everything but I was able to get some stuff at cost and other stuff on a pretty deep discount. I also bought almost all of it at least 6 years ago. Either way you should be able to get some good sound for $300.00. Good audio does not have to cost a lot.
Sammich, those polks look good to me too. For an amp do you want the adjustabilty of a 4 channel amp (fade front to rear) or just a 2 channel amp?
MyKeyB is offline
post #11 of 20 Old 06-06-2013, 07:46 PM
9859limited
Height - 1-1/2"
Width - 2-5/8"
Depth - 1-1/2"
Weight - 3.3 pounds
1 Ohm Stable No
Tri-Mode No
Low-Pass Filter No
Passthrough - No
I'm powering two pairs of Kenwood kfc-709ps component speakers with it and it works awesome.
9859limited is offline
post #12 of 20 Old 06-06-2013, 10:28 PM Thread Starter
sammich
I don't think I'm worried about that (lol). I really just want to be able to push the right levels to the speakers that they need to function appropriately. I had a inexpensive 4-channel amp under the back seat of my 98 TJ and never touched the settings again once I placed them where I felt was right.
2004 Rubicon
sammich is offline
post #13 of 20 Old 06-07-2013, 06:06 AM
alexrule123
alexrule123's Avatar
I was never really a fan of the CDTs I ran, to me they never sounded right. These were what I ran http://www.woofersetc.com/p-4630-ef-...5-tweeter.aspx
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #14 of 20 Old 06-07-2013, 09:35 AM
gily25
The CDTs need to have a lot of power behind them, they're greedy, and a proper tweeter location. I struggled with mine for the longest time until nalinmfg.com made his tweeter braket, it's the perfect location.
gily25 is offline
post #15 of 20 Old 06-11-2013, 09:33 AM Thread Starter
sammich
Any recommendations on another small amp that would provide the Polks the right level of power?
I tend to take the back seat out from time to time, so I'm trying to find an amp that is stashable elsewhere in the vehicle.
2004 Rubicon
sammich is offline
