Tj Mount For Cb Radio - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Tj Mount For Cb Radio
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Bds fox ipf 2.0 racing series shocks now available at rockIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-25-2006, 01:49 PM   #1
jbpdog
Hey. I am looking for a cheap cb radio for the jeep. Was gunns use if mainly for trail ride communication. Does ne1 know of a cheap good CB, or a good way to mount the CB. Keep in mind its a DD. I was gunna run the antenna cable thru the back of the jeep to the tail gate, and thru to the tire carrier so Its an easy mount. I would love to see pics. Im sure there is a threat sumwhere, but no search makes it hard. Thanks guys.
jbpdog is offline   Reply With Quote
Unread 03-25-2006, 03:11 PM   #2
tjchad
Where are you at? I have a decent cheap RS one that I took out to put in a Cobra 75. Ifyou're close to SoCal I can hook you up...
Chad- KI6BIG
'02 SportD442"BB
Pics: [url]http://smg.photobucket.com/albums/v234/tjchad/[/url]
tjchad is offline   Reply With Quote
Unread 03-25-2006, 03:13 PM   #3
idgit0488
My antenna is mounted with a small tab to the rear bumper. I ran the coax under the carpet and through the drain hole under the passenger side floor mat, down the fram rail and to the whip. Any radios made by Cobra or Uniden will last you years to come. You don't want a cheap CB if that's the only line of communication between you and your buddies. If you buy a small radio you can drill it onto the side of the console by your shifter or do what I did and mount it under the glove box. I've also considered building an overhead console out of black diamond plate or a strong steel to mount my rig to. I don't have any pics for you though.
I'm not an urban cowboy, I'm a country plowboy.
idgit0488 is offline   Reply With Quote
Unread 03-25-2006, 04:09 PM   #4
yepitsme
Here's a nice CB mount: http://www.turbocity.com/product_inf...roducts_id=351
Installation Writeup: http://www.rockcrawler.com/techrepor...y_mt/index.asp
Antenna Mount Kit: http://www.walcottcb.com/product_inf...antenna-mounts
Hope this helps!
[B]Mark[/B]
2005 Silver Wrangler X Auto, Rubi Tires & Wheels, Homebrew QD's, Tow Hooks fore & aft, Fisher LD Plow for the white stuff.
yepitsme is offline   Reply With Quote
Unread 03-25-2006, 06:01 PM   #5
countryboy4ya
http://cgi.ebay.com/ebaymotors/RADIO...QQcmdZViewItem
This is the CB mount that I use.....it has been an awesome little unit.
[SIZE=1][CENTER]2001 [B][COLOR=Red]Red[/COLOR] [/B] Jeep TJ Sport. ARB Snorkel, K&N filter, 62MM TB, Banks Exhaust System, Optima [COLOR=Red][B]Red[/B][/COLOR] Top, 5.5" RE lift, Rock Sliders, Painless Cirkit Boss, 4 KC Titanium Daylighters, CB, Inclimeter, Herculiner, Neoprene seat covers, Dana 30 front, Dana 44 rear, 4.88 gears, Novak Conversion T-case Shifter linkage, Teraflex ES SYE kit, 37" Boggers, Currie Steering Conversion, [URL=http://www.supermotors.org/vehicles/registry/detail.php?id=6958]http://www.supermotors.org/vehicles/registry/detail.php?id=6958[/URL] [/CENTER][/SIZE]
countryboy4ya is offline   Reply With Quote
Unread 03-25-2006, 06:02 PM   #6
1BadJeepX06
Perhaps you could mount it inside your console and just open it up when you want to switch channels. Run the cable with the handle through the top with the console closed. I do this with my Ipod sometimes when there is nothing good on the radio. If you run it through the front of the console and close the lid, there should be no problems...
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline   Reply With Quote
Unread 03-25-2006, 11:34 PM   #7
JPWheeler
You can find a decent CB for $40 or so that will work just fine. I would suggest going with a Cobra or Uniden. Same as you, my TJ is a DD and I wanted a temporary mount for the CB as well. I got this idea somewhere on the net and really like it. The CB is attached to the top of the center bezel by velcro and for power I just plug it into the cigarette lighter. When the CB is not in use I just put the rubber thing back in the tray to hide the velcro. This setup works perfectly for me.
As for the antenna, it is mounted to the tailgate with a homemade bracket. Got the write-up from here: http://www.4x4xplor.com/antennamount.html
-Jon
2000 TJ Sport - Forest Green - 4.0L I6 5-Speed, Soft top, Stock D30/35c, 3.73's, RE 2" BB, 1"BL, MML, 32x11.5 BFG M/T's, 15x8 Unique black steelies, JKS QD's, Hanson 52" front, Jeeperman rear bumper/tire carrier, Jeeperman Trail Skidz, Warn 9.5ti w/ Viking Trail Line synthetic rope, Roundeyes H4 headlight conversion, 130w KC SlimLite Titanium Fogs, Pioneer HU w/ iPod integration, Cobra CB w/ Firestik II, Husky floor liners front & rear, Wet Okole neoprene seat covers FTL!
Green Jeep Club Member #80
Colorado Jeep Club Member #58
DD:
98 BMW M3 Coupe, Arctic Silver, 3.2L I6, 5-speed
JPWheeler is offline   Reply With Quote
Unread 03-26-2006, 01:17 AM   #8
RubiconRanger
I picked this place simply because it's out of my way, completely, and still easily accessible. Granted I have a VHF radio and not a mobile CB but I'm sure it would work just the same. There's metal behind the plastic shroud that's under the glove box. Couple bolts and it was in. Very secure. I've never had any rattling, or any shaking for that matter. I also have never had any issues with passengers and leg room.
I mounted the antenna on the tire carrier, and the cable I ran through the tail gate (easily fits through the existing hole for the brake light wires) and then under the carpeting and under the seats.
04 Rubicon - Black
Does anyone's list of goodies they want ever end?
RubiconRanger is offline   Reply With Quote
Unread 03-26-2006, 04:15 AM   #9
joe_jeep
check out the local truck stop. i got a crobra 19dx4 for 29.99 at a ta truck stop, caught it onsale. usually about 39.99. good , cheap, small radio fits jeep perfectly.
at the top of the windshield frame in the middle, the footman loop i un bolted it and hung my cb from the 2 bolts there(no drilling) ran antenna cable to rear along the roll bar up hi cant even see it. can power to lighter or the battery or the fuse box, your choice. good luck
joe_jeep is offline   Reply With Quote
Unread 03-26-2006, 06:30 PM   #10
forcephil
I went to Ambient Weather.com, I purchased a Midland for 34 bucks, that was freight included..... I have removed the sunvisors, so I just drilled a couple of holes through the provided mounting bracket, and then matching holes above the windshield, about as far left as I could go... the radio is just above the main line of sight for me.... I wanted to do the footman loop thing, but I apparently stripped the screws, now the won't come out! So I had to improvise..
forcephil is offline   Reply With Quote
Unread 03-26-2006, 06:59 PM   #11
TJdave
Here is the cb that I got
And here is how I have it moiunted. This is an older picture, since I have added molding around it and cleaned it up a little bit, but you get the idea.
Here is the antennea mount on the rear bumper.
1997 Green TJ
RE 3.5 SF Lift Kit w/ Rancho 9000 shocks
Currie AntiRock and HD steering,
KC daylighters, Warn Front bumper
and some Shrockworks
rock sliders all sitting on 33's
Pictures
NRA Jeeper #9
Ham Radio Call: KI6KCU
TJdave is offline   Reply With Quote
Unread 03-26-2006, 08:03 PM   #12
fried_gold
Mine isn't the best setup but it might give you some ideas. Here's my CB location. It's looks like it's in the way but it's not. Instead of hooking the wires directly to the CB, I used bullet connectors so I can unhook it and take the CB out if I want to. The wires and cable are zip-tied behind the dash so it's pretty clean if the CB is out (I've actually never taken it out). You can see the cable in thic pic but that was temporary, it actually runs behind the dash to the side of the tub, down to the floor and along there to the rear of the Jeep.
I mounted the antenna almostly exactly like TJdave's by drilling one hole through the stock bumper. I did that as a temporary location until I get a bumper/tire carrier but, to tell the truth, I like the location because the antenna doesn't stick up above the roofline. I don't like it on the bumper but I love the height, so I don't know what I'm gonna do.
Depending on how you mount the antenna, here's a good way to run the cable out of the Jeep. There's a rubber grommet thing in the rear corner of the tub near the rollbar that you can run the cable down through. If you want a brake light mount you can take the brake light off and pull the cable through the hole at the bottom of the brake light, then directly to the bracket. That's how mine runs right now and you can see the cable under the license plate in the photo, but if you want a bumper mount of some sort, you can pull the cable out the fenderwell instead, which is probably what I'll do,
fried_gold is offline   Reply With Quote
Unread 03-26-2006, 08:08 PM   #13
97TomsJeep
apologies for hijack .. but ..
fried gold, what is your SWR with the antenna mounted that low?
Looking for new project jeep
97TomsJeep is offline   Reply With Quote
Unread 03-26-2006, 08:49 PM   #14
fried_gold
I don't know, I had someone else tune it. It may be horrible but all I really need is to hear and be heard for a few hundred yards. TJdave's is on the bumper, maybe he knows his SWR?
Unread 03-26-2006, 09:31 PM   #15
TJdave
My antennea is pretty tall and actually reaches up above my soft top so I don't have any interference. I do not remember exactly what my SWR was when i tuned it, but it was pretty low. I have never had a problem hearing or getting reception on a trail from either people in front or behind.
1997 Green TJ
Pictures
NRA Jeeper #9
