TJ brights not working? - JeepForum.com
post #1 of 7 Old 09-22-2009, 04:20 PM Thread Starter
mjw22
Tj TJ brights not working?
I have a 97 Sahara and the brights haven't worked since I bought it and they didn't work for the previous owner either. Turn signals, headlights, reverse lights and driving lights all work, but no brights. It's not so bad except for when I forget and I go to turn the brights on and everything else turns off and then the road disappears haha
Apart from the obvious with the bulbs being spent, what else should I check?
Originally Posted by Son-of-Beast View Post
- Nice interior - because surviving a zombie apocalypse doesn't have to be uncomfortable
♦ Lady Jeeper ♦
1999 4.7L WJ Limited || 1997 4.0L TJ Sahara || 1998 2.5L TJ SE || 1994 5.2L ZJ || 1989 2.5L YJ
mjw22 is offline
post #2 of 7 Old 09-22-2009, 08:43 PM
Itsjustme2see
It's more likely the multifunction switch is at fault.Fuse #12 is the circuit that runs the headlamps.
Itsjustme2see is offline
post #3 of 7 Old 09-23-2009, 06:34 AM
Slithering_Joe
In the '97 service manual, Fuse #10 (30A) in the underhood fuse box (Power Distribution Center) powers the headlamps but if your low beams work then that is not your problem. The RED/ORANGE wire out of the multi-function switch (turn signal switch assembly) feeds the headlamp high beams. The multi-function switch in many cases is the cause of the problem. Check all the "cheap" stuff (fuse, wires, bulb, connectors, connections, etc.) first before buying a new switch.
4.0L TJ
Slithering_Joe is offline
post #4 of 7 Old 09-23-2009, 04:03 PM Thread Starter
mjw22
Thanks fellas, I'll check on that tonight!
♦ Lady Jeeper ♦
mjw22 is offline
post #5 of 7 Old 09-23-2009, 05:19 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Replace the switch, they do go bad. My '97 TJ is on its second turn-signal switch that also controls the high-beams.
Jerry Bransford is offline
post #6 of 7 Old 10-05-2009, 03:22 PM
Moose4052
Interested to see the results. i have followed the schematic back to the multifunction switch as well. though just need a reassurance this is the issue.
Moose4052 is offline
post #7 of 7 Old 10-12-2009, 06:37 PM Thread Starter
mjw22
Found out it was a rotted wire on the back of the driver's side headlight. I'm amazed the lights were working at all! Dug out the rotted wire and reconnected the freshly stripped wire and they worked!
♦ Lady Jeeper ♦
mjw22 is offline
Horn on 97 ZJ stopped working, but then started working again? compcrasher86 Audio, CB & Ham Radios, GPS, & Electrical 0 01-09-2009 03:15 PM
Controlling fogs thru the brights... GIJOE Audio, CB & Ham Radios, GPS, & Electrical 14 10-16-2007 01:44 PM
fog lights turn off when brights are on, how to rid of this? TXjeepTJ Audio, CB & Ham Radios, GPS, & Electrical 8 02-22-2007 12:12 AM
brights rootster Audio, CB & Ham Radios, GPS, & Electrical 1 09-01-2005 01:40 PM
KCs not working Nymisus General Jeep & Off-Road Equipment 4 06-30-2004 09:39 PM
