Quantcast Tips for Satellite Radio (portable) installation... - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Tips for Satellite Radio (portable) installation...
Old 04-13-2007, 04:12 PM   #1
DefStatic
Anyone have any tips or info on setting up a Sirius portable radio?
I have the Sirius Sportster4. I also purchased a direct FM transmitter, cause the built in one sucks.
Looking for suggestions as well on mounting the antenna, as well as mounts for inside the Jeep (98 JGC Limited).
I have been looking at this one http://www.gbxdirect.com/store/uni_mount.php because I would like to mount right next to the radio, and I think this has the clearance needed.
This one http://www.pro-fit-intl.com/Adobe/JP-71-96.pdf is more of a direct fit, but I dislike the mounting location as well as the possible interference with the vent.
DefStatic is offline   Reply With Quote
Old 04-13-2007, 09:31 PM   #2
spd76
I bought the bracket from pro-fit for my wifes durango for her sirius sportster...very good product but way overpriced...
#56 of the Low Output 4Cyl. Jeep Club
spd76 is offline   Reply With Quote
Old 04-13-2007, 11:07 PM   #3
_Kyle_
Hmmmm....
_Kyle_'s Avatar
I just used the included sticky mount and mounted it on the flat piece of plastic next to the radio/by the vents. I then hid the excess 12V wire under the passenger side carpet and then ran the sat antenna cable under the center consoler -> drivers seat -> along drivers side panel -> slit the rear rubber seal to put it through -> finished off by running it up and around the rear hatch -> secured the antenna as instructed by the manual.
-Kyle
1996 Grand Cherokee
RIP Troy (bigbluezj94)
1996 ZJ FOR SALE
_Kyle_ is offline   Reply With Quote
Old 04-14-2007, 11:34 AM   #4
DTarlo
I would reccomend the Pro-Fit as well, shouldn't be overpriced unless you got ripped off, should be about $35 retail.
D
DTarlo is offline   Reply With Quote
Old 04-14-2007, 11:59 AM   #5
spd76
I paid @ $35-40...I just thought it was a little high...but then again...It's the only place i could find the specific bracket that i needed....It is a good product though...
Old 04-14-2007, 12:05 PM   #6
Geeps
I'd go with the Pro-Fit mount, at least you know it will fit without having to bend it.
If you do decide on the Bracketron, shop around a little. That price seems high.
Another option, if you don't mind drilling, is a Ram-Mount. http://www.ram-mount.com
Geeps is offline   Reply With Quote
Old 04-15-2007, 12:02 PM   #7
Davejb
Mount the antenna on the rollbar, just stuff it under the padding and zip it up.
Davejb is offline   Reply With Quote
Old 04-15-2007, 12:28 PM   #8
Rocky529
Jeep
Rocky529's Avatar
Easy in a Wrangler, not so easy in a Grand Cherokee.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 04-15-2007, 12:37 PM   #9
Davejb
Doh!
Glock Forum
