Quantcast For those of you with CJ parking lamps - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > For those of you with CJ parking lamps
Old 10-05-2005, 01:13 PM   #1
Polaris
How did you end up wiring yours? I tested mine by taking the two hot wires into the one positive on the CJ wiring harness and grounded the ground wire. Now only the top (the shorter one) filament of the two stage bulb illuminates when the parking lamp is on, or flashes when the turn signal is started, BUT NOT BOTH! When the parking lamps and the signal is turned on, the relay makes the first on "click" and the arrow dummy light stays on. Never do both stages of the bulb illuminate together. Help!
2000 TJ Sport, 3-speed slushbox
HP30, ChroMoly shafts, Ford 8.8 rear, 4.10s 35s
ORIGINAL Black Jeep Club Member #34
ThePointbreak.org | Mods and Wheeling pics
Polaris is offline   Reply With Quote
Old 10-05-2005, 04:14 PM   #2
Soon2AdjustYou
dont ground them.......when you install them into the grill with screws they will ground themselves. I had the same problem......went ahead and screwed them in and now they work perfect
Former TJ owner...present YJ owner
Soon2AdjustYou is offline   Reply With Quote
Old 10-05-2005, 04:17 PM   #3
joedirt88
Lets see some pics
joedirt88 is offline   Reply With Quote
Old 10-05-2005, 04:33 PM   #4
Soon2AdjustYou
Okay here ya go
Old 10-05-2005, 07:37 PM   #5
Polaris
so the red and black wires are both B+? man! It makes sense now that I think about it... there are two contacts on the bottom that the red and black connect to and the side is also a conductor (ground!)
thanks for the help... i'll post pics in the morning
Old 10-05-2005, 07:49 PM   #6
Soon2AdjustYou
not a problem.....hopefully they work ok
Glock Forum
