teraflex tail light antenna mount - JeepForum.com
post #1 of 8 Old 02-18-2008, 10:12 PM Thread Starter
xltj
there is an optional hole on this mount. has anyone had any issues not using this hole? just curious how sturdy it will be with a 3' or 4' antenna installed.
xltj is offline
post #2 of 8 Old 02-18-2008, 10:15 PM
FTW Rubi
FTW Rubi's Avatar
use the hole, there is a difference. However my sag me be from one of the sons using it for a hand hold or step.
FTW Rubi is offline
post #3 of 8 Old 02-19-2008, 05:23 PM Thread Starter
xltj
Thanks. I did notice the mount can move quite a bit without that optional hole. I'll probably return it since I'm not big into drilling into the painted body of the jeep. I've got some extra angle aluminum and will mount it to the tailgate using the existing holes where the tire carrier used to be
xltj is offline
post #4 of 8 Old 02-19-2008, 06:33 PM
xxxflhrci
xxxflhrci's Avatar
I did not use the hole. However, my antenna is only a 3 ft Fire Fly. It shouldn't put too much stress on the mount.
xxxflhrci is offline
post #5 of 8 Old 02-20-2008, 02:46 PM
rastadog
rastadog's Avatar
Tj
I just installed my mount Monday. In my opinion, not drilling and using the hardware is the wrong decision for 2 reasons:
  1. The mount is to actually ground your antenna to the body of the jeep.
  2. The bolts, that have no nuts, that hold the tail light to the body aren't going to survive even a moderate pull on the antenna.
My instructions actually say to sand the inside of the hole so the bolt is actually touching bare metal to properly ground the antenna. I used my dremel and then after I secured the antenna I wiped it with alcohol and smeared a good glob of silicone for rust protection. It also helps if you have long arms to reach up there.
happy wrenching!
2001 Anniversary Edition Wrangler
2.5" OME HD Lift on ProComp M/T 32"s. Aussie Locker in front. Skid Row armor & fresh radiator fluid.
XM Satellite Radio - SKYFi2 and some cosmetic mods.
rastadog is offline
post #6 of 8 Old 02-20-2008, 04:54 PM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Make sure to mount the Angle centered on the rear of the vehicle.
No matter what Mount you use (I like the Alum. Angle idea) you will need an additional ground strap to guarantee the ground connection.
The Tailgate is not a good grounding point so the extra strap will endure a good ground.
The Antenna/CB System will not work as well without a good ground.
Take a braided strap approximately 1/2" wide with Ring Lugs on each end and run a connection for the Aluminum Angle to the Frame. securing it along the way.
Use S/S External Tooth Star Lock Washers between the Ring Lugs and the metal mounting point and between the Ring Lugs and the head of the bolts.
You can use some Conductive Paste on it too, won't hurt.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #7 of 8 Old 02-21-2008, 02:14 AM
xxxflhrci
xxxflhrci's Avatar
I took care of both issues, by drillng a hole thru the middle of my mount and tub and putting in a rivet in it, before I bolted the tail light back on. Doing that gave me a good ground and strengthened the mounting points, but didn't leave me with any extra holes in the Jeep that can be seen if I decide to take the antenna off later.
post #8 of 8 Old 02-21-2008, 10:23 AM Thread Starter
xltj
I'm not familiar with a 1/2" wide braided strap? Could you provide a link for me?
Some of the antennas come with a grounding wire, so I was thinking to just add a wire attached to the antenna where it mounts, and run it through the tailgate break light hole, and into the jeep, and find some place to mount that end. Wouldnt something like that work?
xltj is offline
Teraflex mount - hole behind tail light xxxflhrci Audio, CB & Ham Radios, GPS, & Electrical 1 12-03-2007 01:45 AM
Attn: Teraflex tail light cb mount owners el guapo Audio, CB & Ham Radios, GPS, & Electrical 3 08-21-2007 01:46 PM
teraflex cb mount (tail light) Drilling question woodb Audio, CB & Ham Radios, GPS, & Electrical 4 11-21-2006 06:16 PM
Who makes a wrangler tail light antenna mount Gary Gill Audio, CB & Ham Radios, GPS, & Electrical 10 08-16-2005 06:10 AM
Q about CB antenna tail light mount.. Shinner Audio, CB & Ham Radios, GPS, & Electrical 9 03-10-2004 11:36 AM
