temp gauge is going from hot back to cold?? - JeepForum.com
post #1 of 3 Old 05-08-2012, 04:58 PM Thread Starter
kyleosb
1978 CJ7
the temp gauge in my 78 cj7 is going to propper running temp then immediately drops to just above cold...its a brand new speedometer cluster with the temp and fuel gauge tied in.. the jeep was warmed up when i hooked the gauge up for the first time,,it went to normal position and almost immediately dropped to alittle above cold. i know its at full temp cause i checked it with my infrared thermometer .. so im assuming its some kind of wiring issue but to me it seems pretty simple cause there is the sender (purple and white) wire and the power wire?? btw it has a new sending unit.. any input or ideas please and thank you
kyleosb is offline
post #2 of 3 Old 05-08-2012, 05:13 PM
Vin
Sounds normal to me. When it drops, it means your thermostat just opened. It was more noticeable in winter with my Yj. It kinda bothers me that it doesn't do it in my JK.
Vin is offline
post #3 of 3 Old 05-08-2012, 05:19 PM
Andywear
x2 on above.
when I changed my t-stat and rad the temp gauge would finialy reach operating temp then drop a 1/4 to cold.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
cj7 , gauge cluster , temp gauge
Temp Gauge Hook-up BobbieJean Engines & Drivetrain 1 02-28-2010 05:07 PM
need help with new temp gauge willyb8 Audio, CB & Ham Radios, GPS, & Electrical 15 04-05-2009 11:37 AM
Temp Gauge Problems NCXJNewbe Street Jeep Forum 4 03-18-2008 10:06 AM
new temp gauge mike4089 Engines & Drivetrain 4 11-24-2005 10:22 AM
temp gauge blackjeep Engines & Drivetrain 0 07-02-2002 01:09 PM
