taurus fan install-switching ground?
| Front and rear Drive shafts @ free shipping | Poison Spyder February Special: FREE Rubber Liners when yo | Slappin' on 61,510 Rigid Industries Lumens for Big Red |
#1 | |
ok, i am installing a taurus fan in my YJ. i am leaning toward wiring such that the ground leg is switched. i think the positive legs are shorter that way and grounds can be found everywhere. are there any disadvantages to doing it this way?
TIA- chuck
nothing i cant do--i'l pay myself $50/hr labor!! the only thing you cannot do, is that which you have already accepted defeat! many people search for god in the eleventh hour, only to die at 10:30 |
#2 | |
Power would always be going through the relay and switch just waiting to be grounded. This could be a problem if something shorts where the other way the switch would have stopped it. However, it should function either way as long as it's wired to the relay properly. However that way the positive legs are the longest. Just FYI. Wiring it with a switched 12V makes it a shortest 12V leg.
Sir G. Cal - 2k Sahara TJ Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more. Quote:
#3 |
never thought of it that way!..thanks. switching the 12v means that the power stops at the switch until it closes, then the whole line is hot. decisions, decisions.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
