talk to me about CB's... - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & HAM Radios, GPS, & Electrical. > talk to me about CB's...
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! All Bilstein shocks & struts - Lowest Prices Ever and 1 Ton Heavy Duty Steering Upgrade Kit. New and Improved d
Unread 10-15-2004, 10:03 AM   #1
NJCJ7
don't need to be talking to the big-riggers out on the open road... i just want to be able to talk to people within a few mile (if that) radius out on the trails... will one of these budget $50 units do the trick?
radio shack sale (click)
[color=blue][b]1985 CJ7[/color][/b] MC2100,TFI, 2.5" BDS suspension, Full Cage, 31" Mud Tires, 1/2" MORE shackles, Aussie Locked AMC 20
NJCJ7 is offline   Reply With Quote Quick reply to this message
Unread 10-15-2004, 10:47 AM   #2
KGBnumber1
i think one of those would work just wonderful for a few mile radius. probably even better. might want to look at getting the 18 dollar cb antenna though.
KGBnumber1 is offline   Reply With Quote Quick reply to this message
Unread 10-15-2004, 10:52 AM   #3
CJ51973
I bought the cheapest one Radio Shack has (like $30). Put it with a whip antenae cut off a little so it will go in the garage. I works well for trail use. I bought a cheap set up so if anybody wanted to liberate it I wouldn't be out much. It can be a little hard to hear going down the road with the top off. In addition to being cheap it is also small which is also a plus. Don't buy a hand held. I got that "bright" idea first thinking I could use it in other vehicles. Hard to drive, pull out the antenae and talk. I have my mike mounted were I can leave it in the mount and just reach up and key it to talk rather than having to handle it.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline   Reply With Quote Quick reply to this message
Unread 10-15-2004, 03:22 PM   #4
CJ5_Fan
1980 CJ5
I have the Cobra all-in-one CB. It has a small unit concelled under the dash and the unit quick disconnects from it for safe storage.
Here is the link;
http://www.cobra.com/index.php?page=...21ef98ebb1.jpg
BTW... Even a cheap CB will work well if you have a good antenna.
CJ5_Fan is offline   Reply With Quote Quick reply to this message
Unread 10-15-2004, 04:00 PM   #5
Jwhit
The only thing you need for a good cb are good transmitt power and a good dipole antenna. dont modify the antenna you buy most of them are calibrated to work with your cb. If you "cut " the antenna you actually alter alot of the good characteristics that it came with.
'85 CJ7 Rebuilt 258/T5/Dana 300 Mopar MPI fuel Injuection kit - 35" Pro Comp X-Terrains,one piece rear axle, 4.56 gears, Tracloc rear, Detroit Nospin front, 2" Full-Traction Shackle Reversal, 1" body lift, 2.5" Sky Jacker lift
'05 Jeep "Willys" ~stock... daily driver
Jwhit is offline   Reply With Quote Quick reply to this message
Unread 10-16-2004, 12:49 PM   #6
OL YELLAH
Get an external speaker from RadioShack for like $12. You'll be able to hear the CB on the highway with the top down. Plus if your CB is capable, you can use the external speaker as a loud speaker and have some fun.
[B]1979 Jeep CJ-5; 1972 258 (Pacesetter Header, Weber Carb, Wrangler Aluminum Intake, 2.5" Exhaust Straight Through w/ Thrush Mufflers); 2.5" BDS Lift; 1" Daystar Body Lift, Herculiner; RJS Belts; 33" Interco Trxus M/T Tires; Xtreme Alloy Wheels; 2.5" Perfomance Wheel Spacers; TFI Upgrade.[/B]
OL YELLAH is offline   Reply With Quote Quick reply to this message
  • CB's?? - Stereos, CB & HAM Radios, GPS, & Electrical. (8 replies)
  • CB's - Stereos, CB & HAM Radios, GPS, & Electrical. (2 replies)
  • do CB's go bad - Stereos, CB & HAM Radios, GPS, & Electrical. (8 replies)
  • CB's...WHERE to put and how? - Stereos, CB & HAM Radios, GPS, & Electrical. (8 replies)
  • cb's - Stereos, CB & HAM Radios, GPS, & Electrical. (4 replies)
