Tail lites not workimg - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Tail lites not workimg
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 07-21-2012, 09:30 PM   #1
Hunkydory
All my lites work, head lites, turn signals, brake lites, 4 way flashers. I have no tail lites. anyone have any idea what the problem is. Bulbs are good and so are the fuses. Thanks in advance: cheers2:
Hunkydory is offline   Reply With Quote
Unread 07-21-2012, 09:36 PM   #2
SnowdogMarc
How have you checked the bulbs?....with a meter? Pull the bulbs out and check with a meter to be sure then check for voltage at the socket. If you have 12v at the socket it's the bulb and if not check your fuses. If the fuses are good then you have a problem somewhere with the wire.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote
