SWR issue - Page 2 - JeepForum.com
post #16 of 31 Old 10-08-2013, 10:56 PM Thread Starter
Agent620
Originally Posted by JPNinPA View Post
I'd start over with basics.
Verify continuity of the center conductor from the back of the radio to the tip if the antenna.
Then continuity and resistance od the outer shield at the back of the radio to a good ground point on the body of the vehicle.
Verify there is no continuity between the center conductor to the outer shield at the radio. Do all without disassembling the antenna just remove the cable from the back of the radio.
Resistance in the ground should be under 5 ohms. The lower the better.
If you do not have these continuities where you should there is something broken, damaged or installed improperly.
You mention your antenna is on the rear tailgate? The hinges make poor ground conductors and cause many SWR issues.
Help me understand what any of that has to do with my issue when my 4ft antenna gets perfect SWR with making no changes to the radio or cable, just swapping antennas. The resistance would be the same as the ground is not changed. Plenty of people use the tailgate as an antenna mount and have no issue, even stu-offroad did it.
I am going to change the mounting bracket this weekend to raise up the antenna above the soft top to see if that helps at all. Until then I am assuming the antenna needs to be taller and that is my issue.
Thanks to Anticanman who gave me a membership!
Chris Hansen is reading this thread.
If you've ever been in that traffic, you would have ground down the steering wheel with a death grip too. "Just ****ing GOOOOOO!!!!"
I pitty anyone who tries to reach into that netting unaware.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #17 of 31 Old 10-09-2013, 12:25 PM
JPNinPA
If you tested the 4ft antenna inside the garage like you did with the 3ft then those SWR readings aren't trustworthy. Disassembling and reassembling could uncover issues like a internal broken stud isolation, Isolation washer. Sometimes weak cables only need some movement to uncover issues with broken center conductors or insulation. This will also test the antenna in the event you have a broken antenna. BTW what brand model antenna are you using?
You are correct. Many do run antenna off the tailgate and many of them add additional ground wires, due to the need of a good RF ground plane.
If you think it's too much trouble, don't do it. At a min check continuity of the shorter antenna.
PS besides the soft top frame is there any other large metal object within 3-4 inches of the load section of the antenna?
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #18 of 31 Old 10-09-2013, 11:33 PM Thread Starter
Agent620
PS besides the sod top frame is there any other large metal object within 3-4 inches of the load section of the antenna?
The swr didnt change outside the garage when testing the 3ft. The 4ft was tested in the driveway the day before.
Cable is brand new, only a few months old. Brands are firefly and firestik.
Nothing near the antenna besides the soft top frame, tailgate, and mount. I will try to test eh OHM's this weekend but until then I have no free time to get the meter out and play with it. The antenna is literally brand new, right out of the package last week.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #19 of 31 Old 10-10-2013, 07:47 AM
Leeworthy
Check swr on 3 channels. 1,19,40
Leeworthy is offline
post #20 of 31 Old 10-10-2013, 08:46 PM Thread Starter
Agent620
See above for those SWR readings.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #21 of 31 Old 10-11-2013, 06:05 AM
Leeworthy
Any reason you want the 3ft instead of 4? The higher the antenna the easier to tune and the better signal you will send and receive. The best antenna is technically a 108" whip. That gives you the best of both.
post #22 of 31 Old 10-11-2013, 09:39 AM Thread Starter
Agent620
Reason is in my first post. I cannot fit in my parking spot.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #23 of 31 Old 10-13-2013, 09:24 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by Agent620 View Post
....my 4ft antenna gets perfect SWR with making no changes to the radio or cable, just swapping antennas.
Although very rare, I might suspect a faulty 3 foot antenna.
What brand/model of antenna ?
CJ7-Tim is offline
post #24 of 31 Old 10-14-2013, 06:04 AM
Leeworthy
I think it's a fire stick. It could be a broken coil
post #25 of 31 Old 10-14-2013, 10:00 PM
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
The problem with an SWR of 2, is you're only effectively radiating 2 watts of power. First, as others have suggested: Make sure you have continuity between the coax shield (outer barrel of a PL-259, or similar), and a part of the jeep that is connected to the frame. For clarity, cable length is not a myth, HOWEVER, when we get concerned with cable lengths is when you get to the 50 foot mark, or thereabouts. You're dealing with a cable that's about 18' which is what a standard pre-fab cable tends to be for CB. Not enough to be concerned with. One thing you can do, is create an RF choke. Basically you make 5 to 6 loops about 5" in diameter. Make the choke where the antenna attaches to the coax. A choke is important, and many fail to do this. Another thing is check your coax. How old is it? has water made its way into connector? This can cause an issue as well. If you're going to replace the coax, I would recommend RG-8X, as it's easy to work with, has low loss for the length you're using, and is not overtly expensive. Get good quality cable though, order it from an Amateur Radio store. If you are having a cable custom made, ask for silver plated connectors, as silver is the best conductor. As previously stated, a 1/4 wave whip will be much easier to tune, ceteris paribus. I remove my antenna before I put my jeep in the garage.
VA3IPB
The only True Professional Mechanic in the Greater Toronto Area for Modified Jeeps, and trucks. If Rock Spyder hasn't seen it before, or done it before, you don't need it.
TheHeretic is offline
post #26 of 31 Old 10-14-2013, 10:14 PM
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
This ^^ Be sure your cable is not looped into a RF choke.
Or pinched by making sharp turns.
Actually, you want an RF choke. You want the antenna to be the radiator, not the feedline.
VA3IPB
post #27 of 31 Old 10-15-2013, 12:18 PM
CJ7-Tim
CJ7-Tim's Avatar
An SWR of 2.0:1 is an 11% loss of power radiated, not 50%.
http://www.firestik.com/Tech_Docs/SWRLOSS.htm
CJ7-Tim is offline
post #28 of 31 Old 10-16-2013, 12:23 PM
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
....And where is the rest of those watts going?? Back into your radio. Sure, it's only a total of 4 watts, but considering the less then steller quality of components used in CB radios, I'd rather not take the chance.
VA3IPB
post #29 of 31 Old 10-16-2013, 06:36 PM
CJ7-Tim
CJ7-Tim's Avatar
Nearly all modern CB's have protection circuits for the finals. An SWR of 2.0 is not ideal, but there are no worries about damage to the radio at 2.0:1.
1.5:1 or less is the target to shoot for. To me, an SWR of 2.0 indicates one or more of the following: poor quality antenna components, faulty antenna components, incorrect installation, poor choice of antenna mounting location.
CJ7-Tim is offline
post #30 of 31 Old 10-16-2013, 08:56 PM
TheHeretic
Kool Kat 4x4
TheHeretic's Avatar
1.5:1 or less is the target to shoot for. To me, an SWR of 2.0 indicates one or more of the following: poor quality antenna components, faulty antenna components, incorrect installation, poor choice of mounting location.
Both my CB and 2m HAM radio operate between 1.2 ~ 1.3. Good quality radios will have some protection, but few CB manufacturers are doing that. I'd be surprised if any of them, other then the ubber high end stuff. I'm not a CB'r so I don't really know what those manufacturers consider to be okay. I know my Yaesu FTM-350 has protection for up to an SWR of 3, but when I bought that radio new it was also $650. A $60 CB I don't think is going to have that kind of protection. I could be wrong, like I said not a CB'r.
VA3IPB
