Subwoofer Solution - Waterproof and fits under back seat! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Subwoofer Solution - Waterproof and fits under back seat!
Brand New! Quadratec LED Headlights!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 09-18-2010, 01:00 PM   #1
YWU
When I bought my TJ, it had a large aftermarket sub taking up all the "trunk" space and getting regularly rained on. I pulled it out but have been missing the sound.
Solution: I just installed the Pyle PLMRBS8 8" Low Profile Waterproof Powered Subwoofer. This unit combines the subwoofer and amplifier into a single unit. It is 3" tall and fits easily under the back seat. Best of all, it is waterproof.
Certainly there are better sounding systems on the market but this sounds pretty good and it was only $135. Exactly what I have been looking for.
I wasn't crazy about the white color but it is completely hidden under the seat so who cares.
PLMRBS8 - 8-Inch Low-Profile Super Slim Active Amplified Marine/Waterproof Subwoofer System Pyleaudio.com ::: Your source for Car Audio, Mobile Video, Neon Lighting
YWU is offline   Reply With Quote
Unread 09-20-2010, 01:56 AM   #2
1LoudZJ
Nice and compact! How well does it pick up 30-45hz?
1LoudZJ is offline   Reply With Quote
Unread 09-20-2010, 09:28 PM   #3
YWU
I hate to admit this but I don't have a clue how to answer that question. I am no audiophile (which is a good thing since I have plenty of other things to spend money on). I'm sure it doesn't sound as good as a higher quality sub in a full box. That said, my stereo sounds 100X better now than before installing this sub/amp. When you crank it up the mirrors shake. It serves my needs well and I still have room in the back for my other stuff.
Unread 09-22-2010, 03:47 PM   #4
jpschacht
do you have a stock head unit or what?
jpschacht is offline   Reply With Quote
Unread 09-22-2010, 04:31 PM   #5
terpsmandan
That looks cool and only takes up space that would normally be unused. Where did you get it for only $135?
terpsmandan is offline   Reply With Quote
Unread 09-22-2010, 08:41 PM   #6
YWU
JVC KD-HDR50 in-dash. I love the front USB for a thumb drive. I also have Polk DB speakers (marine rated). It's not a fancy or expensive setup but it sounds pretty good for my needs. Afterall, an open Jeep rolling down the road is not exactly the ideal environment for hi-fi.
Unread 09-22-2010, 08:42 PM   #7
YWU
TheDeepDiscount.com
Unread 09-23-2010, 07:01 AM   #8
Demp
Lies, you just need enough wattage to overpower the road noise
i've seen that sub used in actual marine applications and does fairly well. As you said it won't compete with full sized higher powered stuff but it definitely beat the stock sub. Even better if you didn't have the stock sub
Demp is offline   Reply With Quote
Unread 09-23-2010, 10:42 AM   #9
ttony
how does it sound with the top off, at highway speeds?
ttony is offline   Reply With Quote
Unread 09-23-2010, 07:47 PM   #10
YWU
What? You'll have to speak up a bit.
Seriously, before adding the sub, I could barely tell what was playing when I was on the highway. Now I can hear it and feel it.
Unread 09-24-2010, 11:24 AM   #11
ttony
great - I think I might try this route. Thanks for posting the info. Too bad the deepdiscount seems like that they are sold out of them, or dont carry them anymore!
Unread 09-25-2010, 10:30 AM   #12
50FRONT
powered sub
i recently added the boss sub similar to the op's. (Boss Bass1500) I mounted it inside the rear seat firing down. The best part is that it takes up no space and the seat can still tumble forward. It does ok for its size and fills out the low end.
1995 SE 4.0 auto - 4" pro comp lift 1" shakles 33x12.5 sye
2006 LJ - Auto - Stock
50FRONT is offline   Reply With Quote
Unread 09-29-2010, 09:42 AM   #13
ttony
YWU - I went ahead and ordered one of these - looks like thedeepdiscount still had them for sale on ebay, but not their main page. I'll let you know how it goes once Im finished with the install.
Thanks for the heads up on this unit!
Unread 09-29-2010, 06:29 PM   #14
YWU
Great! You are welcome. I hope this works well for you.
Unread 09-29-2010, 06:31 PM   #15
Lastshot
Subscribed, this might be what I'm looking for. Bass on a college budget!
{Project "New Start" -'05 LJ build }~{SOLD '98 TJ -"Blue Steel"}
{You know you drive a TJ when....}
gily25 Says...
Issues only become problems when you don't have the tools or time to fix it.
Mike318 Says...
I like my 4.0L like I like my ****... stroked and blown. :duhrock:
Lastshot is offline   Reply With Quote
