-   Audio, CB & Ham Radios, GPS, & Electrical (http://www.jeepforum.com/forum/f20/)
-   -   Subwoofer in Overland WJ Please Help (http://www.jeepforum.com/forum/f20/subwoofer-overland-wj-please-help-1563176/)
dhaliwalia 08-16-2013 05:02 PM
Im loooking to install a subwoofer into my 2003 Jeep Grand Cherokee Wj Overland, which has the infinity sound system. I have the stock nav head unit and would like to keep it. There is already a stock amp and the speakers on the front doors are considered subwoofers but I think another amp may be needed. Can some please walk me through the process and adding a sub to my sound system and the cables and parts I will need?
Thanks!
JohnnyBertone 08-17-2013 07:41 AM
Unfortunately you'd need a new radio head with subwoofer RCA out, depending on why size subwoofer and amp you'll need a wiring kit which comes with power wire with inline fuse, antenna cable and ground cable, then you'd need an amplifier just for the subwoofer, a subwoofer and a box, and about 2 hours
bubbadiesel250 08-17-2013 10:19 AM
Actually you wouldn't have to replace the radio. Search and buy a high to low audio converter. They even sell them at walmart. As for sub and amp it all depends on what you want, then just buy an amp install kit. As for the converter you would tap into your rear speakers and plug your RCA cables into that. Also some amps have the converter built in, in which you would just tap into the rears and run that into the amps high input.
JohnnyBertone 08-17-2013 10:29 AM
I thought the high and low pass splitters were expensive that's why I didn't suggest one but yea you could do that too
kingcat400 08-18-2013 12:33 PM
http://www.sonicelectronix.com/item_5261_PAC-LC2.html
you get a loc and a control knob in one.
http://www.sonicelectronix.com/item_...io-DB1212.html
http://www.sonicelectronix.com/item_...te-P300X1.html
http://www.sonicelectronix.com/item_...VX-XKIT42.html
WJefy 08-22-2013 09:41 PM
2 Attachment(s)
Just did this in my '04 Overland. Wjjeeps has the pin out wiring diagram for your Infinity amp. You'll need the remote turn on lead from that location, as well. I used a $20 PAC generic Hi-low converter, but someone in a different thread posted a $30 PAC converter that just plugs in (cannot verify functionality). Good luck!
wjguru86 08-23-2013 01:36 PM
Most amplifiers have high level inputs on them and would not require purchasing a separate one.
EDIT: sorry bubbadiesel didn't notice you already mentioned that. I'm also going to add that you are going to be tapping into the speaker output of the factory amp. not the audio input from the radio. You can grab the signal from any speaker. And you only need to grab one if you're only running one subwoofer.
The time now is 08:58 PM.
