Quantcast Subwoofer in InstaTrunk? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Subwoofer in InstaTrunk?
Old 10-11-2009, 01:02 AM   #1
Dantheshan
I am pretty sure i saw a picture of this a while ago, but i couldnt find it.
Would it be possible to buy maybe a 10 inch subwoofer, cut a circular hole in my instatrunk and put the sub in it? So the instatrunk would sort of act as a sub enclosure? And im thinking the sub would be facing the back of the back seat. I am really curious if it would sound alright because i keep stuff in the trunk so a box would take up too much room. And if anyone needs more info on the instatrunk, i can take some pictures to help. Thanks guys.
Dantheshan is offline   Reply With Quote
Old 10-11-2009, 07:37 AM   #2
SirGCal
SirGCal's Avatar
No, the insta-trunk isn't sealed off from the main area and you'd get leaks. Results would be less than stellar.
Build a box for the trunk (down-firing) and then clearence out that front area so the box can exit into the vehicle, and you'll be as good as you can get with that type of setup.
Sir G. Cal - 2k Sahara TJ
Living and loving on borrowed time. Life with Multiple Sclerosis. My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline   Reply With Quote
Old 10-13-2009, 12:06 AM   #3
DFWCook
Well you could do it if you went with a Free-Air style subwoofer. These are hard to find now days and the few that are still made are generally sold as Marine subwoofers. However it would still not be a good idea, you just wouldn't get a hole lot of good sound in your application of it.
SirGCal is right on with the Downfire method for your jeep. Especially if you have a soft top. That's how you will get the best output.
DFWCook is offline   Reply With Quote
Old 10-13-2009, 09:29 AM   #4
APEDZ04LJ
APEDZ04LJ's Avatar
heres how i did mine
APEDZ04LJ is offline   Reply With Quote
Old 10-13-2009, 11:06 AM   #5
gily25
I had an instatrunk I sold it and bought a box from www.just4effect.com has a 10" downfiring in a secure trunk.
gily25 is offline   Reply With Quote
Old 10-14-2009, 10:32 PM   #6
Dantheshan
ok thanks for the info guys. what about using a tube sub like the one bazooka makes. anyone have any experience with those? either in the trunk or behind the seat.
Old 10-14-2009, 10:46 PM   #7
DFWCook
I used a 6.5" Bazooka off the factory head unit for over a year. Worked pretty good, but I wanted more bass. Liked the fact that I could unplug it when I needed too as well. I would suggest considering at minimum the 8" one not sure though if its to big for the insta trunk. My Tj never had one so I'm not familar with the space in there.
Old 10-15-2009, 10:00 AM   #8
gily25
You should be able to get the dimensions from bazookas site. Get some cardboard and make a tube and see how it fits. I never had an install trunk in my YJ (only in my TJ) but I know I had a coca-cola carry crate (like vendors use) in that space so I would imagine there is a good chance of a tube fitting in there depending on how the trunk reduces the space.
Glock Forum
