subwoofer!!!!! - JeepForum.com
post #1 of 24 Old 01-29-2007, 07:43 PM Thread Starter
garrett
subwoofer!!!!!
i have a 05 with a stock 8 in the center console do you guys think i could go buy a aftermarket subwoofer and switch them out and put a 300 watt amp or so on. would that sub that work good? or would it rattle loose and sound crappy or would it not work at all? please give feedback on what you guys think! thanks!!!!
garrett is offline
post #2 of 24 Old 01-29-2007, 07:45 PM
raskull
raskull's Avatar
Well, first off I doubt it would fit without modification. The stock sub is very thin. Also, you will need an aftermarket deck with pre-outs in order to plug the amp in.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #3 of 24 Old 01-29-2007, 07:45 PM
Rocky529
Rocky529's Avatar
I would not put anything in the center console.
Buy a 10" sub and amp... mount it behind your rear seat in a custom box.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #4 of 24 Old 01-29-2007, 07:47 PM Thread Starter
garrett
why not put anything there if i put a box under the back seat is easy to see and steel plus it would be cheeper to just put a aftermarket small 8 inch sub (one that would fit) what do you mean pre outs on the deck?
garrett is offline
post #5 of 24 Old 01-29-2007, 07:49 PM
Rocky529
Rocky529's Avatar
Isn't worth it to put one in the console, it will sound bad compared to what you can do for not much more money.
If the box is made right, and bolted down correctly, it will look stock and not stand out to thieves at all.
On your headunit, you need a remote turn on for your amp, along with the audio out cables to go to your amp.
Rocky529 is offline
post #6 of 24 Old 01-29-2007, 07:50 PM
xtremebikr04
You dont need an aftermarket radio with pre-outs to run an amp, they have a $20 adapter that you tap into your speaker wires and on that adapter are pre-outs, its meant to be used with factory stereos or stereos that dont have pre-outs.
2001 TJ D30, D35 3.07 gears 4.0 5 speed.
31inch tires, budget boost, 1 inch body lift, Banks Torque Tubes, Banks CatBack, K&N air Intake, Homemade MAP adjuster, b-quiet extreme sound deadener, b-quiet v-comp noise barrier.
xtremebikr04 is offline
post #7 of 24 Old 01-29-2007, 07:52 PM Thread Starter
garrett
ya hey rocky i was just lookin at your profile pics how did you get that gps that is bad a! does it flip up? i have a hand help i keep haha in the console! oh ya and how doesy our flow master sound? ive been thinkin about puttin one of those too oh and back to the sub what size amp would you recomend to power that 10?
garrett is offline
post #8 of 24 Old 01-29-2007, 07:52 PM
raskull
raskull's Avatar
An amplifier plugs into pre-outs (plugs, RCA connections, not speaker wire) on the back of the deck. That's how it gets it's signal. Then your sub plugs into the amp with speaker wire...
I suggest you find out a little about how aftermarket systems work, and take some measurements of the console.. I haven't checked myself, but I find it very unlikely that any aftermarket sub would fit in there. I would take Rocky's advice and look into getting a small sub box built instead of worrying about trying to fit it in the stock location.
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #9 of 24 Old 01-29-2007, 07:54 PM
Rocky529
Rocky529's Avatar
That is the Jeep Garmin Trail Guide... made for Daimler Chrysler. What you see is what you get, and it is removeable and can tuck away and you can shut the door that says JEEP on it.
Here is the sub I have:
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT10DVQ'&Ser=KPE&C at=SUB
Here is the amp I have:
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='REF611A'&Ser=REF&Cat=AMP
Sounds perfect when mounted in the box built to the specified dimensions.
Rocky529 is offline
post #10 of 24 Old 01-29-2007, 07:55 PM
raskull
raskull's Avatar
Yeah but if you're wanting the sound quality and good bass of an aftermarket system, this is not the way to go. It's basically a cheap fix that sounds bad in comparison to even a lower end brand name $150 deck.. say a lower end Pioneer with pre-outs.
Plus if you buy a brand name deck you will usually get pre-outs for your other speakers in case you wanted to power your midrange/tweeters, and other capabilities, like mp3, satellite radio, etc built in.
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #11 of 24 Old 01-29-2007, 07:56 PM
raskull
raskull's Avatar
Kappas.. VERY nice stuff Rocky!
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #12 of 24 Old 01-29-2007, 07:57 PM
gawdzkitchen
There are several subs that are thin enough to fit either in the console or even under the front seats. Crutchfield.com will tell you what will work, then go online and find the one you want at a better price. Just my $.02.
Everywhere...but nowhere to be found!
Orange Jeep Club Member #1
gawdzkitchen is offline
post #13 of 24 Old 01-29-2007, 08:03 PM Thread Starter
garrett
ya thanks guys
garrett is offline
post #14 of 24 Old 01-29-2007, 08:05 PM Thread Starter
garrett
one more question.. how do i get my pics on my profile?
garrett is offline
post #15 of 24 Old 01-29-2007, 08:09 PM
Adam98TJ
I just built a box that fits in my "add a trunk," put 2 8in Rockford Fosgates in with a 300w amp. The thing pounds. Plus...harder to steal. I would stay away from the console speakers.
Adam98TJ is offline
4 Ohm vs 2 Ohm Subwoofer Stan99 Audio, CB & Ham Radios, GPS, & Electrical 44 11-05-2009 01:18 PM
Subwoofer and Amp Help? cyprian1717 Audio, CB & Ham Radios, GPS, & Electrical 2 02-28-2009 02:48 PM
Subwoofer ??? george318i Audio, CB & Ham Radios, GPS, & Electrical 25 04-03-2008 09:59 AM
subwoofer safarimike Audio, CB & Ham Radios, GPS, & Electrical 6 09-29-2006 10:21 PM
need a little subwoofer help! Euclid34 Audio, CB & Ham Radios, GPS, & Electrical 6 12-27-2004 10:52 PM
