Subs in Jeep TJ. Ill answer any questions on your installation - Page 2 - JeepForum.com
post #16 of 21 Old 11-20-2012, 10:17 AM
BigBlue21
Thanks for the info ill check everything over, it should be all hooked up right to the radio because all I did was unhook the amp but something might have come loose.
BigBlue21 is offline
post #17 of 21 Old 12-09-2012, 12:30 AM
smokey1985
Ok I have a grand Cherokee do you know how to wire the speakers up with out stock amp I bought the jeep and its gone and the speakers is not working all I have is a lot of wires under the seat where the amp was thanks
smokey1985 is offline
post #18 of 21 Old 12-10-2012, 09:45 AM Thread Starter
WhitestAfrican
Okay well follow what ever wires you have to where they go. It would help if you posted a couple of pictures because I would be able to solve it very quickly with pictures. If you can get and pictures, take out the speakers and re connect to them. you probiay have a bad ground.
2006 Jeep TJ with 33s on 17 inch procomp with a 3.25 lift
WhitestAfrican is offline
post #19 of 21 Old 07-27-2013, 06:05 PM
z_paulk245
I have two sundown audio e12's and I was wondering what dimensions I needed for the box and what for the ports and how to face the box. The jeep is a 2005 tj
z_paulk245 is offline
post #20 of 21 Old 08-14-2013, 07:56 PM
gily25
Down firing or rear firing are best bets. Use a box calculator to figure out what size enclosure, check the specs for the subs it'll tell you the enclosure size. Should be roughly twice for a dual chamber.
iPhone app user; excuse typos...thanx.
gily25 is offline
post #21 of 21 Old 04-21-2015, 11:16 AM
Victor348
Hey guys! I was wondering where would be the best place to and a small sub. I don't want anything to big because I do use the rear cargo ALL THE TIME for tools, but i want to put the sub some were it will also be hard for people to steal if I have the top down. Thanks Guys!!!!
Victor348 is offline
amp , music , radio , wiring
