Sub power? Bad Ground? - JeepForum.com
post #1 of 27 Old 10-05-2013, 07:05 PM Thread Starter
thedaringmove
Need some quick help here... Installed sub and amp and a brand new stereo.
Barely getting any power to the woofer. Could a bad amplifier ground be the problem? I've eliminated everything else. Don't try to school me I've done my research
thedaringmove is offline
post #2 of 27 Old 10-05-2013, 08:15 PM
Indy
Indy's Avatar
Turn up the gains.
I'm the only gay eskimo.
Indy is online now
post #3 of 27 Old 10-05-2013, 08:58 PM
Scopez
1994 ZJ
What's the specs on the sub/amp?
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #4 of 27 Old 10-05-2013, 10:23 PM Thread Starter
thedaringmove
350 rms amp
Kicker 800w 2ohm
post #5 of 27 Old 10-05-2013, 10:26 PM Thread Starter
thedaringmove
Amp is by sound ordinance. The ground is not the problem... I think the amp isn't putting out enough power. Fuses are all good??? Super confused about all this.
Speakers are supposed to be plug and play
post #6 of 27 Old 10-05-2013, 10:43 PM
Scopez
1994 ZJ
Everything tuned? Kicker is 800 max? 400rms? Should be plenty. What gauge power wire? Inline fuse amperage? Getcha a volt meter on the power wire to verify its getting the right power to the amp.
I've never had this problem with my systems. I'm running 2 JLW613v2s on a JL Slash v2 1000\1, Kenwood excelon HU.
Scopez is offline
post #7 of 27 Old 10-05-2013, 11:00 PM Thread Starter
thedaringmove
Everything tuned? Kicker is 800 max? 400rms? Should be plenty. What gauge power wire? Inline fuse amperage? Getcha a volt meter on the power wire to verify its getting the right power to the amp. I've never had this problem with my systems. I'm running 2 JLW613v2s on a JL Slash v2 1000\1, Kenwood excelon HU.
I've never had this problem either.
Correct on the Kicker
80 amp inline fuse. Don't remember the gauge but it's the max that fits in the amp socket.
It's gotta just be a sucky amp
post #8 of 27 Old 10-06-2013, 07:59 AM
Scopez
1994 ZJ
I've never had this problem either. Correct on the Kicker 80 amp inline fuse. Don't remember the gauge but it's the max that fits in the amp socket. It's gotta just be a sucky amp
What's your gains at? If it's anywhere close to max, then it's a terrible amp. Probably doesn't push what it says it's rated for.
Scopez is offline
post #9 of 27 Old 10-06-2013, 10:21 AM Thread Starter
thedaringmove
My gains are all the way up. Just straight pissed. I hate when companies bs customersq
post #10 of 27 Old 10-06-2013, 01:17 PM
Lastshot
If everything is hooked up right, Did you check settings on the Head unit?
{Project
-'05 LJ build }~{SOLD '98 TJ -
{You know you drive a TJ
gily25 Says...
Issues only become problems when you don't have the tools or time to fix it.
Mike318 Says...
I like my 4.0L like I like my ****... stroked and blown. :duhrock:
Lastshot is offline
post #11 of 27 Old 10-06-2013, 08:45 PM Thread Starter
thedaringmove
Yea I even put in a different stereo to make sure. Just a bad amp
post #12 of 27 Old 10-07-2013, 06:36 AM
JeepNicholson
Why? Your amp gain should match your HU output, no more, no less.
JeepNicholson is offline
post #13 of 27 Old 10-07-2013, 08:11 AM Thread Starter
thedaringmove
Because it's not loud enough. That's kinda the whole point of this thread
post #14 of 27 Old 10-07-2013, 08:28 AM
JeepNicholson
Well yes, I got that, but gain is not volume, which is my point.
Amp gains are to adjust the amp according to the strength of the signal coming from the head unit. Gain does not directly affect amp output.
http://www.bcae1.com/gaincon2.htm
post #15 of 27 Old 10-07-2013, 09:03 AM Thread Starter
thedaringmove
Well yes, I got that, but gain is not volume, which is my point. Amp gains are to adjust the amp according to the strength of the signal coming from the head unit. Gain does not directly affect amp output. http://www.bcae1.com/gaincon2.htm
By gains I had assumed he was talking about like the "bass boost" function... I'm not ire where the gain level is at. I'll have to look
