Sub enclosure idea, need opinions - JeepForum.com
post #1 of 2 Old 03-05-2003, 09:55 AM Thread Starter
idcx3
I am currently running a fasgate DVC power 12 mono bridged to a fasgate power 1000A2 amp..my enclosure is a 1.25 sealed Qlogic wedge style box = WAY to much power to the sub,lack of any deep base and on deep notes the sub makes a noise that sounds like its trying to detonate...this is all at the lowest gain settings
My solution,
Just got off ebay where i found another power 12 DVC for 150 My idea is to build a custom enclosure basically to the dimensions of the back cargo area ( i dotn have my back seat in because no one likes me )in this enclosure i am going to have 2 seperate spaces apx, 2 feet wide and 4 feet long ( however long the jeeps back cargo area is) the subs will be apx 1 foot away from the back of the seat firing directly in the back.
I had the idea of porting one of the enclosures and keeping the other enclosure sealed tight so i would get both the punch base and the deep rumble of a ported box any know if this idea would work?
Also, what would be the ideal way of connecting this system? both subs are DVC, so there are many ways to connect them...any help appreciated!
idcx3 is offline
post #2 of 2 Old 03-06-2003, 07:56 AM
SirGCal
RIP
SirGCal's Avatar
The specs for the Rockford Fosgate Power 1000a2:
250x2 @ 4 Ohm
500x2 @ 2 Ohm
1000x1 @ 4 Ohm
Now, from what I can find on the net, Rockford does not recomment running below 4 Ohms bridged on that amp although some people have reported 2 Ohms no problem, 1 Ohm detonation.
Now.. The problem. How is your single DVC wired?
Do you
1) have the pos & neg from the amp going only to one coil of the speaker? (VERY BAD!)
2) have the positive and neg from the amp going to both positive and negative coils? (Parallel)
3) have the amp pos to the coil 1 pos; the coil 1 neg to the coil 2 pos; the coil 2 neg to the amp neg (Series)
If your speakers are 2 Ohms per coil the following will result.
1) 2 Ohm load. (however will blow the speaker easily since one coil is not powered)
2) 1 Ohm load. (Running to the amp bridged, the amp is in ganger and putting out way too much power, likely around 3000w potential at 1 Ohm)
3) 4 Ohm load. (Running the amp at recommended bridge.)
If the speaker has 4 Ohm coils, then the following will result.
1) 4 Ohm load. (Still bad. Never run only one coil of a DVC)
2) 2 Ohm load. (likely overpowering for your sub still showing 2000W to the speaker)
3) 8 Ohm load. (Running the amp at 500W, likely within the power range of the sub. Should sound pretty good)
Now for more info:
if the new speaker isn't exactly the same as the old one, I wouldn't put them together. They would likely sound mushy together.
Porting one and sealing the other is a great idea for good sound, however, never do this on the same amp. The speakers respond different and will sound very muddy together like this most often.
Running the amp at minimum gain is not a great idea. Try to keep it at least above 1/4. This allows the amp to actually function. Running at minimum gain doesn't let the amp work and it is most likely clipping. (sounding like the speaker is going to pop)
As far as how I'd run it? It ALLL depends on:
- what the sub are specifically
- what components are backing the system up
- what power the components have
- how many components there are (other speakers)
My MS/Life blog, Audio and Electronic write-ups, project how-tos, pictures, stories, and more.
Originally Posted by SirGCal
If you can't take a nano-second to press shift/period/etc. and make proper sentences and paragraphs, I don't know if I can take a few minutes to respond to your topics... It doesn't have to be perfect by any means, but a little effort goes a long way.
SirGCal is offline
need opinions on winch idea The Shoveller General Jeep & Off-Road Equipment 9 09-16-2009 10:05 PM
got an Idea need other opinions WVmountaineer Audio, CB & Ham Radios, GPS, & Electrical 3 09-17-2008 11:29 AM
sub enclosure ? txjeep103 Street Jeep Forum 3 04-23-2007 02:52 PM
sub enclosure king_kong Audio, CB & Ham Radios, GPS, & Electrical 15 01-30-2007 10:19 AM
sub enclosure... ldogg Audio, CB & Ham Radios, GPS, & Electrical 5 02-08-2003 11:18 AM
