Quantcast Stock Subwoofer replacement Found!! - Page 7 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > Stock Subwoofer replacement Found!!
Old 07-21-2009, 08:46 AM   #91
gily25
The kicker has a different wiring set-up (single voice coil, SVC, 4 ohm) so while it can be wired to work with the factory amp you're only going to get about a third of the power. Look back thru this thread...I think we have the wiring configs discussed.
gily25 is offline   Reply With Quote
Old 07-28-2009, 10:59 AM   #92
ajlduc
Alright, I got the bazooka, installed it without too much of a problem, but I still have no sound. I have power to the amp at the wiring harness plug. It must be the amp?
At this point I'm thinking I should install a cheap amp under the seat.
I didn't mind the stock sound so I have a tough time justifying spending too much money.
Can anybody give me some direction?
Also, if I get an amp, I need to figure out which of the eleven wires in the console will be connected to the amp. Any wiring diagrams out there for an '06 unlimited?
Thanks
ajlduc is offline   Reply With Quote
Old 07-30-2009, 08:46 PM   #93
blackattak
Nice info here as looking at some upgrades to stock (however have been impressed with stock system with subwoofer as stock)
2004 LJ- 33X12.5 Mickey MTZs, Mickey Classic II wheels, 4.88 Yukon Gears, 3" BDS SL, Rockhard Rear Bumper with Tire Carrier & Rockers. Oil Pan, Warn Gas Tank Skid. & Differentials armoured, Iggee Seat Covers, Warn M8000 winch.AEV TT & tranny skid, radiator & steering box skids
blackattak is offline   Reply With Quote
Old 07-31-2009, 08:57 AM   #94
gily25
I was mostly happy with the 7 speaker set-up when I first got my wrangler. Then over time from leaving the top down and playing music with low bass frequencies my factory sub started to fail on me. It's usually with that failure most people decide to upgrade. Depending on your listening tastes and how much you drive the Jeep, this will be sooner or later.
Old 12-17-2009, 08:19 AM   #95
OffRoad98
Seems this subwoofer (kicker Comp VT 08CVT652) has been discontinued in 2-ohm. There is a 4-ohm available now. Luckily i was able to score a 2-ohm model on Amazon for about $65. This thread has been very helpful as im currently in the process of building up my stereo system!
OffRoad98 is offline   Reply With Quote
Old 02-03-2010, 01:27 PM   #96
denalijb
Time to bring this thread back from the dead. So if you've read this whole thread you know that i put the bazooka sub in as a replacement. It required some modification, but provided fairly decent sound.
Of course it's never enough. I've had a decent CDA-9815 Head unit in there for years. I have no want or need to change it. It wheels with me everywhere i go and has worked fine....
I did decide I wanted a little bit more from the bazooka and decided I also wanted sub control from the 9815 sub outputs. As you probably know ( I didn't), you can't really do this with the stock amp. The head unit puts out enough power (rear channels plus stock amp) to make the sub sound decent. But if you want to isolate the sub, it needs its own amp. So...
I have the bazooka, its dual voice coil. What AMP (small footprint, dirt cheap) would be best. Mind you, I'm not an audiophile and do not want a flame thrower aimed at me for not knowing f'all about it.
I thought maybe this was a decent option. JVC KS-AX3002 2-channel car amplifier — 65 watts RMS x 2 at Crutchfield.com
Thoughts?
denalijb is offline   Reply With Quote
Old 02-03-2010, 01:30 PM   #97
denalijb
Also.. Where the heck do you put it?
It'd be nice to put it in the console. Under the seat scares me. I'm also open to somewhere behind the dash.
Old 02-03-2010, 01:32 PM   #98
RUBtjICON
My stock sub is blown now. Kind of freaky you brought this back up now.
2004 TJ Rubicon........My build thread, My URE Vid
www.vanc4x4.net
All Who Drive Jeeps Are Not Jeepers - Willy 3:16
RUBtjICON is offline   Reply With Quote
Old 02-03-2010, 01:38 PM   #99
denalijb
I "think" this sub is 100 Watt... I'm not sure yet though. I noticed on a bazooka forum that they wouldn't give up the specs for the speaker. Which is kinda crap.
I assume the specs are 100W (RMS?) at 2 ohm, dual voice coil...
Old 02-03-2010, 02:06 PM   #100
RUBtjICON
I picked up a 2 ohm Kicker off Ebay new for $60
www.vanc4x4.net
Old 02-10-2010, 06:46 PM   #101
higginsems
well im in the blown sub boat so what i have read is you can use the Kicker with the stock amp i dont care if its better i just dont want it to sound bad but i want it for a little bass... has anyone bought that 10$ one? or is the kicker the way to go?
or this one?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160395469302&ssPageNam e=STRK:MEWAX:IT
SOLD........ 99 jeep XJ 8-10" tons and 38s
Now......... 04 Rubicon 2"BB 1"BL 33s" Rokmen w/ XRC8 KCs
[URL="http://www.jeepforum.com/forum/f9/my-reasonable-rubicon-build-pics-1033731/#post9475793"]My "Build"[/URL]
[QUOTE=lumpster;8744844]Its hard to do anything right on a budget.[/QUOTE]
higginsems is offline   Reply With Quote
Old 03-18-2010, 11:15 AM   #102
robtre
Anyone know where I can get the enclosure part?
His:2005 Wrangler Rocky Mountain Edition
Hers:2005 Grand Cherokee Laredo
robtre is offline   Reply With Quote
Old 03-18-2010, 02:18 PM   #103
RUBtjICON
Yea, make me a decent offer...lol
www.vanc4x4.net
Old 03-18-2010, 02:25 PM   #104
robtre
I need the insert for the console with or without the sub in it I plan on replacing it anyway I just want to buy the enclosure if you have it. $40 + shipping?
Old 04-03-2010, 11:56 PM   #105
IDArmyTJ
As time passes, so do the subs mentioned. I'm not sure what all is wrong with mine. I'm pretty sure the sub is blown (goes in and out if I'm on a rought road), but still plays at degraded quality. My tweeters sometimes goes in and out, also.
Has anyone found a small amp that'll work? Looks like the Bazooka is no more, so are there any other DVC 2ohms our there?
31x10.5 Duratracs on stock susp. Banks headers, exhaust, and some other engine stuff.
Build
Youtube Channel
-Just emptied every pocket. Everyone starts somewhere.
IDArmyTJ is offline   Reply With Quote
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
