#16 | |
Oops, sounds expensive!
Good Find, also so a good replacement amp on that sight.
(81 CJ, 92 YJ, 97 TJ, All Gone) 05 TJ Rubicon Stupity Kills, but not nearly enough. |
#17 |
where is the amp
and does anayone know what it's rated at
K&N pannel filter, got that far before i ran out of money |
#18 |
Wired in parallel. The 2 ohm amp is mounted to the back side of the enclosure. The Comp VT is a 2 ohm amp, not sure what wattage. Granted you can run a higher rated amp, great if you are 20 yrs old again and want thump, the stock amp sounds clean and gives a much better hit then stock.
The only mod you need is there are ribs in the enclosure that need dremeled down,about 5 minutes of work. Also new holes for the mounting screws for the new subwoofer. It is actually really easy, the most time consuming part was removing the console and sub enclosure from center console. Not sure how to post pictures. Any help? Thanks Slick101, also threw in a picture of my new pedals , , ,![]() Last edited by USMCTJ; 02-24-2008 at 08:47 AM.. |
#19 | |
#20 | |
Oh and in the last pic, I see you're missing a pedal.
Matt 2001 Jeep Wrangler Sport 4.0L - Amber Fire Pearl Coat 1981 DeLorean DMC-12 VIN: 2953 |
#21 |
Looks Good, But how does it sound for real? I like base but I am not trying to drive around with two 10 inch subs in a large *** box taking up my entire trunk you know?
2006 Rubicon Unlimited Khaki: AUTO, 4:11 D44/D44, REBB /w Mono tubes, Rancho front stabilizer, 31 x 9.5 LT245/75R16 MTRs, Stock 16in Moab Wheels, Olympic Reverse-A-Bars,KC Daylighters on windshield brackets, Garmin Nuvi GPS, Pioneer Sound, 3A fire extinguisher, Line-X interior... www.stevensinger.org <-- Photography website Hello, my name is Steve and I am a Jeepaholic. LJ Owners Member 155 Rubicon Owners Member 123 New Jersey Jeepers Member 44 |
#22 |
It is a huge improvemement over stock, but by no means, license plate shaking. A nice thump when needed, I changed out my front speakers to 5 1/4's and upgraded my sound bar as well, so the Comp VT is a nice rounded addition. The stock sub, always sounded somewhat "muddy" to me, where as this "hits".
#23 |
ya I'm looking for something beter too. i have a 12in sub and everything else to hook it up but it won't work in my jeep with either mudd rain or getting stolen with top off. is the center consol a PITA to get off.
#24 |
No the center console is only three screws and a cannon plug. The sub enclosure is only a couple more screws and some patience.
#25 |
Any update? No problems with the load presented to the amp??? Looks good
Russo |
#26 |
Just violated my Parole
i would try to build an enclosure for a larger sub on the inside of that, but it would be hell
im going to see if i can build a pair of boxes that would be slanted and fire at the driver and passenger seat rails and get rid of this rear seat. that way i can maintain my cargo area, have a "stealth" box setup and they'll be protected from the elements relatively well |
#27 |
That's one of many but thanx for the install pics:
also check out these other 6.5" subs when shopping. Especially if you plan to add an aftermarket amp. www.hemphop.com www.elementaldesigns.com www.cdtaudio.com you can even do the cheap tangband 6.5 from partsexpress.com if you're on a budget. www.jlaudio.com/ (altho that's common nowadays) focal and morel make 6" subs if you want to spend a lot and have a LOT of sound in a small package. |
#28 |
forget the audio, i'm more into the 'running shorts' on the hemphop.com site... nice...
Russo |
#29 |
Too bad they don't make seat covers! ha! Seriously tho...in my 94 YJ everytime it would rain the Jeep would smell like...ahem...hemp.
iPhone app user; excuse typos...thanx. |
#30 |
Does the amp mount in the console? Does the amp run just the sub or does the amp run all the speakers? Im thinking that I can get away with running my highs with the radio and replace the sub amp to run just the sub.
Nice find by the way. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
