Stock Subwoofer replacement Found!!
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | Spartan Lockers FREE SHIPPING Excellent Prices | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |
I have been searching for a stock replacement woofer for my 2006 Jeep Wrangler Sport. I wanted to keep the wiring and stock amp. Kicker now has a new 6.5 Comp VT shallow Sub out in both 2 ohm and 4. I went with the 2 ohm, minor mod of the interior sub plastic enclosure. Took about an hour all together. Hits much better then stock, while still maintaining stock appearance. Sub was $99.
#2 |
Wahoowa
Where did you get it at? I blew my factory sub long time ago and haven't been able to find any 6.5" subs to replace it with. Do you have any pics?
White 01 TJ Sport 4.0 NV3550 |
#3 |
#4 |
Demonic Jeep Freak!
http://www.crutchfield.com/sells direct replacements.Most need more power to sound good.
#5 |
I found this one which is about.... 10x cheaper
Its prob. 100x better than the stock one. Prob. not as good as the kicker ( 99.9% sure on that one ), but its less than 3 gallons of gas, should fit, and will prob. be happier with the stock amps power level.Plus... Its $10 Get two and give it to a jeep buddy for X-mas.
2002 TJ Apex edition with EFI ford 5.0L H.O., NV3550, 33'' Maxxis A/Ts, 5'' lift with custom built rear 4-link, Ford 8.8 LSD 4.10s, HP D30 with spartan locker 4.10s |
#6 |
did you have to get an amp for the kicker comp vt?
#7 |
No, the stock amp has four wires going to stock sub. 2 hot and 2 ground, I took both and soldered them together and hooked them up to the single hot and ground leads into the comp VT. No additional amp.
Granted a seperate amp would probably sound even better but the stock amp and Comp VT are night and day compared to the stock sub and good enough for my needs. |
#8 |
Wow... What a tard, I didn't even post the link...
http://www.teptronics.com/pw677.html
#9 |
I'm thinking about putting a 8" in there, do you remember how much width there was with the stock sub/amp removed? The woofer I am looking at is about 4.25" deep
#10 |
hah i never even got a stock sub in mine so this sounds great to me..
#11 | |
Is the stock amp 2ohm stable ? Is it wired parallel or series on the stock sub ?
2004 TJ Rubicon........My build thread, My URE Vid www.vanc4x4.net All Who Drive Jeeps Are Not Jeepers - Willy 3:16 |
#12 |
The stock sub runs at 2-Ohm from what I've read.
#13 |
#14 |
You get what you pay for
your stock amp doesn't put out nearly enough wattage for that sub. Maybe half of what it should be receiving, at best.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville “Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain † Christian Jeep Club † Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38 |
#15 |
any pics of install and what mods had to be done to console?
2002 TJ Wrangler Sport with 6 inch suspension lift, 35x12.50x15 BFG M/T and 15x8 Cragar Soft 8's with 4" BS, 4.88's, 8000 lb warn winch, cold air intake, interior completely rhino lined |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
