Quantcast stock subwoofer - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Electrical, Audio, GPS, & 2-Way Radio > stock subwoofer
TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-RoadGenuine Italian leather shift boots for your Jeep!
Old 10-09-2006, 04:32 PM   #1
skigrl1283
stock subwoofer
I have an 06 SE that did not come with the center console. Well this weekend I bought one and it came with the factory subwoofer. Where is the harness that I would connect to the factory woofer harness? Under the front console? Behind the dash?
Also, will it matter that I have an aftermarket head unit?
skigrl1283 is offline   Reply With Quote
Old 10-09-2006, 04:41 PM   #2
BCwrangler
Long time Jeep fan
BCwrangler's Avatar
I'm not sure, but wouldn't you need the 7 speaker stereo system to have the harness.
BCwrangler is offline   Reply With Quote
Old 10-09-2006, 04:49 PM   #3
skigrl1283
thats what i was wondering. i didnt know if maybe it came prewired.
Old 10-09-2006, 05:27 PM   #4
mylt1
i posted in the other thread you started about the same thing. i doubt the factory wiring is there. also you would need the factory amp.
mylt1 is offline   Reply With Quote
Old 10-09-2006, 06:07 PM   #5
TXST8tj
the factory amp is connected to the stock sub enclosure. it's actually a part of it. it is wired the same as a low level line inverter deal.....basically spliced into the rear speakers. your 4 speaker setup won't have the harness or the wires pre-run, but it won't be difficult to run your own. along with the speaker wire to splice inline with the rear speakers, you will need to run a power wire, a ground, and a remote turn on. the sub/enclosure should have one end of the harness attached. you'll need to clip off the grey plug part and splice into those wires, or you could go to a dealership and pick up the other end of the harness and just plug the two together.
Patrick
Build Thread
Goodyear-Corbeau-Hella-DDM Tuning-Alpine-Kicker-JL Audio-Tuffy-KC-Bestop-Firestick-Cobra-Skinny Pedal-Rough Country
TXST8tj is offline   Reply With Quote
Glock Forum
