stock radio works but doesn't play sound - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Stereos, CB & Ham Radios, GPS, & Electrical. > stock radio works but doesn't play sound
Unread 07-23-2013, 02:00 PM   #1
johnjames
I just got this 97 jeep grand cherokee limited but the radio was not in it so l put it back in but it doesn't play sound. this is my first jeep so can some one please help thanks
johnjames is offline   Reply With Quote Quick reply to this message
Unread 07-23-2013, 11:36 PM   #2
Indy
Does it have speakers?
I'm the only gay eskimo.
Indy is offline   Reply With Quote Quick reply to this message
Unread 07-24-2013, 06:55 AM   #3
johnjames
The kid i got it off of took one out because it had water damage but i put a new one in from a junk yard
Unread 07-24-2013, 05:09 PM   #4
Glasssplinter
1994 ZJ
Do you have the infinity system? Think the amp is under the rear seat. If so, you may have problems with that. Easiest thing is to buy an aftermarket stereo and bypass the infinity system if you have it and be done with it. Work better then factory stuff anyway.
'94 ZJ, 4.0L, 231 TC
Icom V-8000 with 1/4 wave
Glasssplinter is offline   Reply With Quote Quick reply to this message
Unread 07-27-2013, 05:42 PM   #5
johnjames
Thank it was the amp just got one from the junk yard for now
