Stock fog light male connectors? - JeepForum.com
post #1 of 9 Old 01-28-2017, 01:13 PM Thread Starter
BigCanoe
I need to find some male connectors for the stock fog lights for a 2004 TJ. I want to reconnect the fog lights to the stock female ends that are still in place under the front of the Jeep. Any tips on where to find these cheaply?
2004 TJ Wrangler Sahara 5 Speed
BigCanoe is offline
post #2 of 9 Old 01-29-2017, 05:05 AM Thread Starter
BigCanoe
This is the best option I have found for new connections:
http://www.quadratec.com/products/97109_0905_14.htm
For used, folks say the battery tray sensor on a Durango or WK will work, I haven't verified yet.
BigCanoe is offline
post #3 of 9 Old 02-03-2017, 07:48 AM
turbogus
1978 CJ5
Another resource is Mouser Electronics, their online catalog is exhaustive but the results can be filtered easily once you get the fields figured out;
http://www.mouser.com/Connectors/_/N-5g
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #4 of 9 Old 02-03-2017, 09:50 AM Thread Starter
BigCanoe
That site is amazing, I am looking but I havent found it yet.
BigCanoe is offline
post #5 of 9 Old 02-03-2017, 04:01 PM
turbogus
1978 CJ5
Yep! Even the most obscure connectors are available and you can normally order one of one, rather than a pkg. of 20, 50, 100.
turbogus is offline
post #6 of 9 Old 02-05-2017, 06:34 AM Thread Starter
BigCanoe
I spent some time at LKQ this weekend and found a bunch of connectors. The trick is to look at the battery tray for older Cherokee, Durango, Ram. There is a sensor there, looks like a round piece. You can turn it and pull it up. You are looking for ones that are wired directly, without a connector. Follow the wire from this sensor to the wiring harness and you will find a male and female connector of the proper size. I came home with 6 of each as the charge you for the whole connector.
BigCanoe is offline
post #7 of 9 Old 02-07-2017, 02:00 PM
KevbOliver
great resource!
KevbOliver is offline
post #8 of 9 Old 03-20-2017, 09:48 AM
Scrodd
I have the same issue , The male end is under the fender so by cutting off the male end on the new harness it will work Im sure the dealer doesnt carry them
Scrodd is offline
post #9 of 9 Old 03-20-2017, 10:06 AM Thread Starter
BigCanoe
Ya the junk yard is the way to go! I got both male and female connectors in one fowl swoop.
BigCanoe is offline
