Still Trying To Locate The Fuse Box ? ? ? - JeepForum.com
post #1 of 6 Old 08-11-2006, 11:26 AM Thread Starter
schooner
Question Still Trying To Locate The Fuse Box ? ? ?
Hi Guys
Don't remember if I posted this already ~ I'm having brain farts.
Anyway(s) I own a 2001 Jeep Wrangler and the back brake light over my spare tire went out.
Took the bulb out and low and behold its was dark and burnt. So I replaced it.
Still no brake light. I got a test out and checked the shocket and NO JUICE coming out the shocket. O.K. I though I'll check the FUSE BOX ~ YEAH RIGHT !
I couldn't find the darn thing. Looked under the dash, both side. Looked in the engine compartment ~ NO SIGNS OF IT ANYWHERE !
Maybe the sucker in on my roof
Do any you gentlemen know where the heck that fuse box is
So that I can see if the FUSE IS BLOWN !
THANKS GUYS
GOD BLESS
Schooner
schooner is offline
post #2 of 6 Old 08-13-2006, 12:38 AM
kbtriumph
kbtriumph's Avatar
Look behind the glove box. Remove the limiting strap and rotate glove box down, there should be a fuse block back there.
'43 GPW Rock Crawler
'74 CJ6 Safari
'98 TJ DD
kbtriumph is offline
post #3 of 6 Old 09-03-2006, 07:24 PM Thread Starter
schooner
I Found It ~ Thanks
Of all the places to put a fuse box. Thanks for the location of it guy.
schooner
schooner is offline
post #4 of 6 Old 10-31-2010, 07:58 AM
jeeps95
if it's the same connection as on a 95, if the fuse didn't fix it, sand paper the connections at tail door
jeeps95 is offline
post #5 of 6 Old 11-02-2010, 12:13 AM
Demp
you can also remove the little plastic guard on the tailgate contacts and see if one of the wires has decayed/corroded or gotten cut over the years by the tailgate.
Demp is offline
post #6 of 6 Old 11-06-2010, 10:13 AM
Photog2000
Holy old threads Batman!!!!
Photog2000 is offline
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty Audio, CB & Ham Radios, GPS, & Electrical 6 03-05-2010 08:27 AM
CB - ground. To fuse or not to fuse? FunkyCold Audio, CB & Ham Radios, GPS, & Electrical 18 02-12-2009 06:05 PM
wiring a fuse into the existing fuse block... can it be done? CAPCDT388 Audio, CB & Ham Radios, GPS, & Electrical 1 11-14-2008 02:07 AM
Need to locate one more part to complete this swap for my D44 Lud04X Engines & Drivetrain 2 02-22-2007 11:38 AM
Painless Wiring Fuse Boss and Ignition hot fuse Rivka Audio, CB & Ham Radios, GPS, & Electrical 14 08-22-2006 11:38 AM
