Steering Column Electrical connection - JeepForum.com
post #1 of 7 Old 11-05-2010, 11:04 PM Thread Starter
jeledgerwood
I recently bought a 99 TJ with a 6 cyclinder, 5-speed. The airbag trouble light is lit all the time, the horn & cruise control don't work. I took the airbag off thinking that an electrical connector was unplugged, but all looked connected. There are no blown fuses. I still think it is something in the steering column. Anyone have any ideas what the problem is?
jeledgerwood is offline
post #2 of 7 Old 11-05-2010, 11:23 PM
PlatinumNiner
Better be very careful removing air bags. That goes off in your face while working it can kill you. As for the problem its probably the plate between the wheel and column its called the clock spring.
PlatinumNiner is offline
post #3 of 7 Old 11-05-2010, 11:25 PM
PlatinumNiner
post #4 of 7 Old 11-06-2010, 07:31 PM Thread Starter
jeledgerwood
Yea, I followed procedure when removing the airbag, I saw the clock spring, but all the connections looked good. How does it go bad? Just not sure on how it works. Can you explain?
post #5 of 7 Old 11-06-2010, 09:01 PM
PlatinumNiner
Im not really sure of exactly how it works either. They just wear out or they can be damaged while installing a lift or steering box. People dont think and they spin the wheel while the box is free. You cant just spin the wheel or you will damage the clock spring. That may very well be what happened to yours.
post #6 of 7 Old 11-07-2010, 07:57 PM Thread Starter
jeledgerwood
Gotcha, thanks for the info. I'll add a post if that fixes it. Thanks again.
post #7 of 7 Old 09-19-2012, 05:00 PM
Myjeepdestroys
Replace the clockspring yet?
Myjeepdestroys is offline
airbag , cruise control , electrical , horn
jeep cj yj tilt steering column Gary83cj7 Engines & Drivetrain 0 08-27-2010 08:54 PM
Steering column heat at elec connector gdk10 Audio, CB & Ham Radios, GPS, & Electrical 2 12-17-2009 03:10 PM
amp under steering column Chester405 Audio, CB & Ham Radios, GPS, & Electrical 5 01-22-2009 04:42 PM
Steering Column - Cancelling Cam kyburz Engines & Drivetrain 0 12-21-2008 11:19 PM
Steering column broke *theft* etnies88 Street Jeep Forum 3 11-27-2006 09:24 AM
