Starter draw amperage? - JeepForum.com
post #1 of 3 Old 09-27-2013, 07:51 PM Thread Starter
MJeep13
I have had a few instances lately where the engine cranks a while and stops then fires right up when I try again. Got the starter, alternator, and battery tested. 98%battery, alternator was fine, starter draw read 170. What should the starter read? Any other suggestions?
MJeep13 is offline
post #2 of 3 Old 09-28-2013, 07:19 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
180 amps is normal/average voltage for a 6 cylinder starter to draw.
I would suspect loose or corroded wire connections, and/or internally corroded wires as the cause of the symptoms you describe.
CJ7-Tim is offline
post #3 of 3 Old 09-28-2013, 08:15 PM Thread Starter
MJeep13
Thanks, I'll check it out!
MJeep13 is offline
